Help - 2610 won't start, suspect Voltage Regulator
   / Help - 2610 won't start, suspect Voltage Regulator #1
mtimber
Mount Sterling, Ohio
YM 2610
Help - 2610 won\'t start, suspect Voltage Regulator
Had the tractor out last Saturday and mowed for about an hour, shut down and when in to eat lunch and there was a brief rain but when I went back to the tractor a couple hours later it would not turn over. Tried to jump the battery but no luck. Got the voltmeter out and the battery showed about 12.8 V DC. Checked all connections at battery, starter, alt and everything looked tight. Started playing with things and noted that sometimes the charge light on the dash would come on when I turned the key to on and sometimes it would not. Left the tractor alone until the next day (last Sunday) and checked it out again. Turned the key to on and the charge light illuminated, turned to start and I just got a click or clunk from the starter. Turned the key back to on and no charge light. Repeated a few times with the same results. Let the tractor rest for awhile, turned the key to on and got the charge light, tried the turn signals and they would flash but the draw eventually killed voltage and the dash charge light went out and turn signals stopped. Let tractor rest and signals would do same again, let rest tried headlights and immediately killed voltage. Tested throughout the week and found the tractor would maintain the signals and eventually the headlights but would not turn the starter. Tested the VR (that is the small cylindrical unit attached to the top of the starting motor, where the positive lead of the battery attaches, right?) with a voltmeter. With voltage at battery at 12.8V, voltage across VR was 12.7V with key off, dropped to 11.4V with key on, and voltage across VR would slowly drop when turn signals where turned on, more quickly when headlights were turned, and immediately drop to zero when tried to start. Let tractor rest for 10-15 minutes and voltage across VR would go back to 12.7V but would drop again as previously described.
Does this sound like a bad VR? If so where is a good place to get a replacement? Do I need to get a factory part from one of the tbn dealers or are there crossover parts that will match from say NAPA or JD?
Thanks /forums/images/graemlins/confused.gif
   / Help - 2610 won't start, suspect Voltage Regulator #2
Re: Help - 2610 won\'t start, suspect Voltage Regulator
The 12.8 or 12.7 volts you have measured is plenty to turn the engine over. The cylinder on top of the starter isn't the VR, it is the bendix which acts as a solenoid to put power to the starter, and throws the starter gear to engage the flywheel. The drop to 0 volts measured across the bendix when you turn the key to start is normal.
I don't understand why the voltage should drop over time when you turn on the lights, and then recover when you let the tractor sit. This could indicate a bad ignition switch.
Here is what I would try. The bendix should have two large posts and a single smaller one. One of the large posts will have a cable running to the positive terminal on the battery. If there is a cover on that post, pull it back to expose the post and nut that holds the cable onto the bendix. Pull the small wire off of the small post on the bendix. Make sure the tractor is in neutral, with the brakes locked. If you have a remote starter switch, connect one lead to the large post, and one to the small post. Now close the switch to see if the engine cranks. If you don't have a remote starter switch, take a screwdriver and CAREFULLY short across the large (bat+) post, and the small post on the bendix. This will put power to the bendix to engage and power the starter. If this doesn't turn the tractor over, then you have bad connections, a bad bendix or a bad starter.
Get back to us with the results.
   / Help - 2610 won't start, suspect Voltage Regulator #3
If the signals kill battery voltage in a short amount of time and the headlites kill it right now, It sounds like the battery has an internal short and its draining itself.
And sometimes when this happens a jump start will not work. You need to get that battery out of there and replace with a known good one. Be sure to check the charging system if you get it started.
   / Help - 2610 won't start, suspect Voltage Regulator #4
You could also have a bad connection at the battery like the cables or clamps. They will sometimes act that way. I would check them first, before anything else. And be sure and clean the battery post, as a dirty post can also make a bad connection and do the same thing. Been there and done that, myself.
   / Help - 2610 won't start, suspect Voltage Regulator #5
Be sure to check and clean where the ground wire connects to the frame. Mine started fine in the morning and after lunch it wouldn't do a thing. Battery had a full charge. Removed and cleaned the ground wire and all was right with the world.
Mark
   / Help - 2610 won't start, suspect Voltage Regulator #6
As Wellcraft says, I had the same type of problems and it turned out to be the negative cable connection to the frame. I removed the connection, cleaned the cable end and the frame where it was connected with a wire wheel on a drill and reconnected. No problem since.
Re: Help - 2610 won\'t start, suspect bendix
Thanks for all the help so far - as you can tell I don't know a whole about engines but I can usually figure things out with a little help, and a tractor is a good place to start learning.
Well, this is where I am at. I went ahead and checked the neg batt terminal and it had a clean connection to the frame, probably replaced when I purchased the tractor ~ 1yr ago. I didn't suspect there was a problem here anyway since I was getting power to all lights. Also, I put a new batt in the tractor in January so it should be strong.
I bridged the wires across the bendix (assume this was to rule out the ignition switch) and got the same results as before, just a click in the starter but not enough juice to turn it over. It sounds like we've narrowed things down to the bendix and/or starter? All other connections seem clean and tight. Is the function of the bendix to store extra current to help turn over the starter? Could the response from turning on signals and lights point to the bendix as the culprit? I don't have a wiring diagram so I'm not sure how the lights are wired/connected with relation to the bendix or what relationship there is between the bendix and power that goes to the lights. I have also tried tapping the starter since I know they sometimes get 'stuck'.
Thanks for all the advice - let me know where to go from here. /forums/images/graemlins/confused.gif
   / Help - 2610 won't start, suspect Voltage Regulator #8
mtimber,
The bendix does not store energy for the starter. It's mainly a solenoid/switch for the starter. What is the battery voltage when you short across those 2 posts?
By the way........I just live a few miles North of you and we share the same employer.........different departments, but the same guy signs our paychecks /forums/images/graemlins/grin.gif
Jerry
   / Help - 2610 won't start, suspect Voltage Regulator #9
Did you check both battery connections? I have saw this problem many times and it is almost always a poor connection. The small lights dont need much metal to metal to work but head lights take more and the starter takes a bunch. I would try to start it a time or two the feel for a warm connection at the battery and ends of the big cables from the battery. You said it rained just before the problem, and a little mousture and a corroded terminal could make a poor working connection stop working.
Re: Help - 2610 won\'t start, still baffled
Done messing with the tractor for tonight - too dark now. Used fine grit sand paper to clean both battery terms and neg connection at frame. No change. When I turn key to on, turn signals will usually light, headlights will sometimes light, and starter will give me no more than a click/clunk. Once I try the starter things seem to short out and the dash charge light will not even illuminate until I let the tractor rest. Tonight battery was showing about 12.6V DC with no load, dropped to about 12.5V with either the turn signals and/or the headlights illuminated but suprisingly showed no change when I turned over the starter and things shorted out. This makes me think that the problem is with the starter or the bendix. But could a problem in the starter or bendix cause the irregularities in the lights? I also noticed that the turn signal would sometimes blink at different rates, sometimes at the normal speed and sometimes much slower, but always at full brightness. Any suggestions? The bendix/starter or just an electrical short somewhere? Thanks for the continued help everyone.
PS. Hi Inspector507, or should I say neighbor. It's funny, we sit down in front of our screen, log on to the internet and end up getting advice from a co-worker who lives just down the road. Thanks for the advice.
Mark
2021 Club Car Carryall 500 Utility Cart (A51691)
2021 Club Car...
Intermodel Metal Storage Crate (A51573)
Intermodel Metal...
IMPORTANT PLEASE READ!!!! TERMS AND CONDITIONS (A51572)
IMPORTANT PLEASE...
2021 CASE IH 345 LOT NUMBER 12 (A53084)
2021 CASE IH 345...
2013 International DuraStar 4300 Box Truck, VIN # 3HAMMAAL1DL085200 (A51572)
2013 International...
