Hello...I'm new here
   / Hello...I'm new here #1
vmorton
Piedmont of North Carolina
I have two David Bradley walk behind tractors, neither have an engine. Some implements also
Just wanted to say Hello and to say thanks for allowing me on your forum. I am semi-retired from teaching and was looking for a hobby to pursue. I ran across two David Bradley walking tractors without engines but otherwise okay shape. I remember these from when I was a kid and a neighbor had one to work his garden. I hope to get one or both of these going to do some playing in the dirt. Also, I have a disc harrow, breaking plow, middle buster, and a blade. They are all in pretty good shape. The first thing I already have no idea about is the type oil one uses in the gearbox. I want to relubricate everything as a first step. Thanks again for including me in your group.
   / Hello...I'm new here #2
G'day to you vmorton: Let me extend a warm WELCOME ABOARD to you and to say you are most welcome here. In fact, by the sounds of what you say already, I would think this is the perfect place for you to spend some time.
Unfortunately, I personally am not acquainted with your particular tractors, so I will not venture a "guess" at the oil you should use. If you are going to do some restoration, it is important to do it correctly,..... the "first" time.
I have no doubt, someone with expertise will arrive shortly and make the proper suggestions. It is amazing the experts that check in from time to time,...so just be patient. I wish you good luck with your projects.
CHEERS!
. . tug
   / Hello...I'm new here #3
Welcome VMorton
Great place here to learn about tractors. Not familar with the David Bradleys, but have a Gravely walk behind. They are tough old tractors. Enjoy your new hobby. Next thing you'll have an older Ford or Ferguson or something else you'll be rebuilding.
2018 GMC Sierra 2500 4x4 Crew Cab Pickup Truck (A50323)
2018 GMC Sierra...
2016 Ford F-450 Cab and Chassis Truck (A51692)
2016 Ford F-450...
2021 Liebherr L556 (A52748)
2021 Liebherr L556...
2017 Taylor-Dunn B0-248-36 Electric Utility Cart (A50322)
2017 Taylor-Dunn...
2020 Utility Trailer Manufacturing, 53' Trailer (A52384)
2020 Utility...
H & S High Capacity Hayrake (A50515)
H & S High...
