Hello from South Africa
   / Hello from South Africa #1
kariba
Nelspruit Mpumalanga South Africa
Ford 5000
Hi, I have a Ford 500 tractor from the early 70's that I use for cutting fire breaks in autumn each year.
I have 150 acre smallholding near Nelspruit in Mpumalanga, South Africa.
I have a Ford 5000 tractor, not sure of the year but I believe it is somewhere in the 1970's.
My grand children pulled the alternator wires out and I don't know where they go, hope someone can help.
There are 6 terminals on the back of the alternator as follows:
2 terminal nuts, one marked W and the other +
There is a small spade connector next to the + nut marked Aux.
There are 3 spade connectors in a separate housing, a small connector marked Ind and 2 large ones both marked +.
   / Hello from South Africa #5
Welcome!
You should post another post in one of the maintenance subforums to get your wiring answer. You'll get more eyes on your Q there. Good luck and that sounds like a good old tractor.
Perhaps someone could take a quick photo of their wiring for simplicity.;)
   / Hello from South Africa #6
:welcome:
Giyi Auger (A53316)
Giyi Auger (A53316)
Toro Workman Low Profile Spray system 175 (A50322)
Toro Workman Low...
2007 Honda CR-V SUV (A53424)
2007 Honda CR-V...
Case VAC Tractor (NOT RUNNING) (A50775)
Case VAC Tractor...
Gravely 260Z 60in Zero Turn Commercial Mower (A55787)
Gravely 260Z 60in...
2014 Nissan Murano AWD SUV (A55758)
2014 Nissan Murano...
