Hello from PEI Canada
   / Hello from PEI Canada #1
peimitsu
Out in the country P.E.I. Can.
Mitsubishi M21D
Hello tractor people! I acquired a Mitsubishi 4wd tractor with my property. It was working fine until Monday. I was in low range cutting grass while backing up under trees, when I pulled ahead to shift to high range the lever moved but the tractor is stuck in low range. I posted under the tractor section so if anybody can help my fix this problem, it would be greatly appreciated.
Larry
   / Hello from PEI Canada #2
Welcome to TBN!
Hope you enjoy it here, and hope you get your tractor fixed!
Case IH 1666 Combine (A50514)
Case IH 1666...
Bale Ring (A50515)
Bale Ring (A50515)
EZGO (A50324)
EZGO (A50324)
10' Feed Bunk (A50515)
Mini Forks (A50322)
Mini Forks (A50322)
2014 GMC Sierra 1500 4x4 Crew Cab Pickup Truck (A50323)
2014 GMC Sierra...
