Hello from MI
   / Hello from MI #1
440SixPak
USA, Michigan
Kubota L3450
Hello new guy here although I have been visiting off and on for a couple years. I aquired a Kubota from a friend of mine when I recieved it it did not run due to a baseball size hole in the engine block. Last winter I split it sleeved and welded the block had the crank welded ordered a used rod and piston on the net got a rebuild kit from Kubota and got it running. I have used it off and on this summer and it seems to run very good so far. I have plans to build or adapt a backhoe for it hand make a couple more implements for it that I have seen here. This site is great for ideas and helpful tips on anything to do with tractors I love it.
Dirk
   / Hello from MI #2
Welcome,
By the sounds of it your skills and knowledge will benefit others of us here. Congrats on the tractor work and it working.
   / Hello from MI #3
Welcome to TBN Dirk.
Jump on the keyboard anytime and share w/us. :)
2004 Dodge Ram 1500 4x4 SLT Crew Cab Pickup Truck (A50323)
2004 Dodge Ram...
Michelin CARGOXBIB High Floatation Tires (SET OF 4) (A52748)
Michelin CARGOXBIB...
2016 FORD F-450 9FT SINGLE AXLE DUMP BODY (A52141)
2016 FORD F-450...
10 x 18 Transfer Auger (A50515)
10 x 18 Transfer...
1994 Alumatech Frameless Dump Trailer (A50514)
1994 Alumatech...
2016 Kubota RTV-X1100CR-A (A47384)
2016 Kubota...
