hello from ky
/ hello from ky #1
love4god
barbourville , KY
homemade
i have browsed the forums for a while,alot of great info
here is my homemade tractor, thanks godbless
/ hello from ky #2
welcome!!! What did you use for a clutch and Trans?
/ hello from ky #5
Love the name! Welcome!
Special use tractor?
/ hello from ky #8
Nice job. Did you build it for a special task or just because you had the ability to do that level of a project?
/ hello from ky
thanks guys,,not for a special task. it started as a cheep mtd, not much mtd left as i kept breaking it
im running a half ton chevy front end that i narrowed welded solid for posi in the rear, and half ton axel for the fromt with the stump cut out, a 4 spd bulldog trans and a case hydro motor , chain driving the 4 spd,
and a 18 hp vanguard to run the pump, my only trouble now is leaking hydro npt fittings , soon to change over to steel lines,lord willing , i couldnt afford a new tractor so i had to build one, one piece at a time lol,, thanks godbless
/ hello from ky #10
Thanks for sharing, sounds like fun, although it was likely a headache at times. Ed
/ hello from ky #11
that is AWESOME!
That looks like something my old man would have done. Myself, I am all papered up (two of those degrees in engineering) and I couldn't touch some of the skills tractor guys have! Truly impressive. You should be real proud of that. I wish I could do that.
/ hello from ky
ya it had its challenges ,but that's with anything homemade, thanks ED godbless
/ hello from ky
that is AWESOME!
thank you godbless
/ hello from ky #14
Very nice tractor, Welcome :)
/ hello from ky #15
:welcome: to TBN...enjoy.
2003 PETERBUILT PB330 DUMP TRUCK (A58375)
2003 PETERBUILT...
2011 GROVE TMS900E TRUCK CRANE (A58214)
2011 GROVE TMS900E...
2026 Quality steel dump truck (A56859)
2026 Quality steel...
2016 Ford F-150 Pickup Truck, VIN # 1FTMF1C85GKE26496 (A61165)
2016 Ford F-150...
Water Tank (A61570)
Water Tank (A61570)
MASSAGE CHAIR (A58214)
