Hello Fellow Members
   / Hello Fellow Members #1
Tinman236
South Windsor,CT 06074
Kubota B21
After reading many forums on compact tractor snowblowers, I dicided to sign up to TBN, as I am in the market to buy one after just scooping out Blizzard Nemo that came through CT this month.Thanx to all who post their logical ideas and experiences. Tinman236-- Kubota B21 with factory TL421 FEL / BT751 BH
   / Hello Fellow Members #4
:welcome:
Thanx for the welcome-- I have been actively researching the correct and most practical size rear pto snowblower for my Kubota B21. It specs 13.5 PTO HP @ 2564 RPM. After Blizzard 2013 and a solid 28" fall, I somewhat struggled clearing 5 residential driveways (10,000 sf ),with the FEL, backhoe installed and no chains. I think a 54" Bervac Blizzard would run fine, but nothing wider. The engineers would probably recommend a 48" width. Then there is a large weight difference when you drop the hoe to mount the RM SB. I would put chains and some ballast if needed, as spinning your wheels is a waste. Remotely controlled chute rotation and chute deflector is almost a must around the houses, garages, and shrubbery, whatever! I would appreciate any sound advice/opinions. Thanx--Tinman236
   / Hello Fellow Members #7
Welcome to the forum.
   / Hello Fellow Members #8
Welcome to TBN:thumbsup:
   / Hello Fellow Members #10
Geetings and welcome to TBN.
Kinkaid 1200 LS-PH Towable Hydroseeder (A51691)
Kinkaid 1200 LS-PH...
Chevrolet C8500 Flat Bed with a Moffet Kit (A53472)
Chevrolet C8500...
2007 Ingersoll Rand P185WJD Towable Diesel Air Compressor (A52377)
2007 Ingersoll...
Wells Cargo Enclosed Trailer (A53117)
Wells Cargo...
2013 UTILITY VS2RA 53FT REEFER TRAILER (A52141)
2013 UTILITY VS2RA...
JOHN DEERE 2032R LOT NUMBER 223 (A53084)
JOHN DEERE 2032R...
