Hello everone
   / Hello everone #1
sanfordw
4300 John Deere
I got off on the wrong foot with this chattting and forum stuff. I was what I was told highjacking. But to get to my problem with a 4300 SST four wheel drive toy with front bucket and bush hog. I have tore the rear right side down, top off, pullled back plate and top shaft and clutch packs. Problem was busted spider gears. With some fussing and cussing was able to remove the axle gears, spider gears, and cross shaft and bolt, without pulling the carrier. That where the cussing came in, just regular dirty words. So if anyone can help let me know. Footnote, a buddy told me locking the rear is most likely what cause the spider gears to give. Thanks to everone for your time. Thanks sanfordw:thumbsup:
   / Hello everone #2
sanfordw:
I can't help you with you problem, specifically. But, I'd suggest you start a new thread under the forum that covers your manufacturer...if its a John Deere, put your question under that forum...if its Kioti, put it under that forum. Or maybe under the General Forums/Parts and Repairs forum.
You'll probably get more responses that way than under the new member introductions forum.:thumbsup:
Good luck!
2017 Nissan Sentra Sedan (A50324)
2017 Nissan Sentra...
2020 Ford F-350 Pickup Truck, VIN # 1FTBF3A68LEC75327 (A51572)
2020 Ford F-350...
2007 Hino 268 Truck, VIN # 5PVNJ8JT072S50704 (A51572)
2007 Hino 268...
GORBEL EASY ARM LIFTING ARM (A52472)
GORBEL EASY ARM...
2015 FORD TRANSIT XLT (A52472)
2015 FORD TRANSIT...
