hard head
Hi all...I have been visiting this forum for awhile and finally signed up tonight. Originally, I was visiting while I was tractor shopping, but decided to put that on hold. Now, I am here as a member needing help trying to help my friend with his Mahindra 4110 (2005+/-). So here is what happened........
Tractor was running fine while we were doing a little work at farm. It became low on fuel, so filled it up from the diesel barrel without realizing barrel had a lot of water in it. Tractor ran fine for a moment and then quit. We drained tank, removed filter, and turned engine over a few times to clear the lines. Topped tank off with clean fuel and it ran fine. I was present when this occurred.
On the same weekend or maybe the next, cannot remember now, and not sure how many hours later but couldn't have been over 8-10, tractor was being used with tiller attached to PTO. I wasn't present when this happened, but they said the motor suddenly began running at much higher rpm's - to the point the manual kill switch had a hard time killing it (cannot kill it with key..another story) and the fan blew apart. Not sure if the fan coming apart is significant since tractor has several years of wear and tear, but the rpm's were no doubt jacked up. Finally, the engine quit and would not restart. No knocks, rattles, or unusual smoke before it stopped running.
Weather has been nasty for a few weeks, and more on the way, so it will be a week or so before I can provide specific feedback to questions or suggestions you may have.
I am going to start from scratch and make sure fuel system is clean and free of air. I assume this model has injector for each cylinder, and will crack each open to bleed. I hope the issue is a carryover from the water/fuel problem earlier..maybe some stabilizer that wasn't mixed made it rev up.
Is there a safety mechanism that might have tripped due to the PTO being engaged when the high rpm's occurred that I need to check? Do you have other suggestions with starting points?
On a side note, in reading threads, I found that solenoid may be why we cannot turn off engine with the key. So I will fix that if I can get it running again.
Thanks for your help. Again, we have rain in the forecast for several days, so I may not be able to provide feedback until later since tractor is at different location, but if you can give me a list of things to begin my search/ troubleshooting with I will greatly appreciate it.
