hello all
   / hello all #1
cody323
Mountain Home Idaho
Yanmar 187D
I am the new owner of a 187d. the tractor has 600 hrs and seems to be in good shape. i am new to the world of yanmar and am learning as i go. i had to replace the hydro pump and i am having some issues. i bought the pump from hoyes ( i hear they are great to do business with, any thoughts?), anyway i noticed that the pump shaft was very hard to turn, i had to use a 17mm wrench to turn the shaft, is this normal? like i said i am learning all of this as i go. i have a 5 acre "hobby farm" and i hope this little tractor will work out for me. i would like to get a 4' box scrapper and maybe a disc. any suggestions on the size of implements i can use? it came with a alamo smc 2405 fel. i have not got to play around with it (because of the hydro pump) but look forward to putting it through its paces. can anyone give me some advice on what this little tractor can handle i.e. lifting cap. and towing weights? i thank you all in advance for the help and i look forward to being a part of the yanmar world and this site! with a little luck, maybe someday i can return the favor and have knowledge to help some else out. thanks again!!:):)
Cody
   / hello all #2
hi and welcome, congrats on your 187d!
   / hello all #3
I would call Hoye about the pump. It may be taat it just needs some lube but put it on take it off then do it again. Call is cheap. The 4 ft box is the max for that tractor. It will handel a standard or heavy duty. The light duty is of little use. Disk? What are you planning to do with it? Will a tiller do the job. Yanmar tillers are usually cheaper than a disk. Your tractor has plenty of power to the wheels but it is short on tracton. Decide what you want to do and then ask what equipment will get the job done. I have had a few plesant suprises doing this.
   / hello all #4
Welcome Cody to TBN and Yannie Ownership. I have got alot of use out of mine.
Hoye is a pleasure to do business with. Terry
2005 INTERNATIONAL 4300 24FT BOX TRUCK WITH TRANSLUCENT ROOF (A52577)
2005 INTERNATIONAL...
2018 Ford Explorer AWD SUV (A51694)
2018 Ford Explorer...
2017 JOHN DEERE 8270R LOT NUMBER 189 (A53084)
2017 JOHN DEERE...
2012 Nissan Rogue (A50324)
2012 Nissan Rogue...
2002 Wacker RD11A Tandem Smooth Drum Roller (A51691)
2002 Wacker RD11A...
2019 KOMATSU WA380-8 WHEEL LOADER (A51246)
2019 KOMATSU...
