Oil & Fuel heavy smoke
   / heavy smoke #1
sbp30
I have a bx23, with a severe smoking problem. Already have swapped injectors, also if i unhook the #3 injector it quits. Tried unhooking the return but same outcome, heavy smoke.
Im thinking injection pump.
   / heavy smoke #2
I have a bx23, with a severe smoking problem. Already have swapped injectors, also if i unhook the #3 injector it quits. Tried unhooking the return but same outcome.
Now wait a minute I thought this varmint was a direct injection 3 cylinder engine?
You have a bad injector allowing too much fuel into the number three cylinder.
Leonz
   / heavy smoke #3
I thought this one was still indirect TVCS, but I could be wrong.
But what would that have to do with anything? Don't the direct injection engines still use a mechanical injection pump? Direct refers to the combustion chamber and injector design, not the pump technology used.
   / heavy smoke
Yes it is a 3 cylinder. It has a inline injector pump (p-pump if you are a cummins person).
It seems like the pump is injecting #3 heavily. No matter if i change the injectors around. If you disable #3 no smoke, of course it runs badly.
   / heavy smoke
pulled pump off, will post outcome of autopsy.
   / heavy smoke #7
Could you have a compression issue on #3 Vs a bad injector?
Roy
   / heavy smoke #8
I'd think that something is wrong in the three hole!!! Injectors are set to spray at a certain pressure, they also will carry a minimum pressure just below the blow pressure and I've not seen a injector pump through to much pressure to one hole before.
   / heavy smoke #9
It is quite possible that the delivery valve for #3 has stuck open delivering full fuel all the time. Poor compression would not produce large amounts of black smoke.:)
2018 Honda CR-V LX SUV (A50324)
2018 Honda CR-V LX...
91013 (A48082)
91013 (A48082)
2014 Peterbilt 384 T/A Day Cab Truck Tractor (A51692)
2014 Peterbilt 384...
2009 Ford Econoline E-350 Cargo Van (A50323)
2009 Ford...
RIGID TOOLBOX (A52472)
2016 CATERPILLAR 239D SKID STEER (A51242)
2016 CATERPILLAR...
