Heavy Rear End
   / Heavy Rear End #1
MrFixit
South Florida
KAMA 354C
I have a KAMA 354C with a 600 LB grapple up front. I'd like to add some more weight to the rear end to balance things out a bit. I already have rear Wheel Weights.
I thing 500 pounds would balance things out and give me better traction. Filling the tires is one way but I'm looking for a removeable solution.
Before I try and "Reinvent the Wheel" has anybody found a way to Add extra pounds to the rear? maybe a rack with Concrete filled buckets?
Tim
   / Heavy Rear End #2
You could make up a weight box or equilivent for the 3 point hitch. I made one for my buddy's big JD. Picked up a used (could buy new from a farm store or TSC) side link bar, a empty 30 gallon drum, a piece of stock fabricated for top link. Filled drum with concrete.
It was cheap and works as a balance weight. Unfortunately you have to remove to use 3 point.
   / Heavy Rear End #3
I advertised in the local free paper for used barbell weights. It seemed everyone has these laying around from their kids. And were glad to give them away. I now have several hundred pounds of weights.I took a weight bar.fitted the ends the size of my 3 point arms and can add 1-200 pounds quickly and easily. If more is needed a easy frame can be made. A plus is that they can be dropped on the floor and rolled into a corner when not needed. /forums/images/graemlins/laugh.gif
   / Heavy Rear End #4
This cost me just 15$ in materials. I used an old cattle feed tub that protien lick had come in, a spare 3pt drawbar, and some bags of sakrete, a piece of bar stock cut for a toplink bracket, and some misc lag bolts, nuts and washers to bolt the creted bucket to the drawbar..
Ads 600-700# easy.. cheap, and fast..
If you ever ditch it, run 2 nuts and lockwashers of fthe bottom and reclaim the 3pt drawbar, and just dispose of the concrete chunk..
Soundguy
   / Heavy Rear End
Yep, That concrete filled bucket would balance things out just fine.
Thanks!
Tim
2007 Chrysler Pacifica SUV (A51694)
2007 Chrysler...
2018 WACKER NEUSON RTSC3 ROLLER (A53426)
2018 WACKER NEUSON...
2005 Ford F650 SVI Crew Cab Hazmat Truck (A52377)
2005 Ford F650 SVI...
MachPro MP15Pro Mini Excavator, NEW! (A52384)
MachPro MP15Pro...
1985 Miller Wildcat 350-D Welder (A51691)
1985 Miller...
