Heavy Duty Bush Hog Blades
   / Heavy Duty Bush Hog Blades #1
Dodgeboy328
Massey Ferguson 231S
My dad has a 2004 Massey Ferguson 231S and a 5 foot Modern bush hog of the same year. He's lived on his property since the 80s and always bush hogged his pastures with no major issues. It's just overgrown hayfields with some small trees and scrub. He's gotten a few seasons behind on his mowing this time around, but nothing worse than he's mowed before.
On his current cutting he's snapping bush hog blades off about an inch below the bolt hole. Now on this third set of blades purchased locally on this cutting alone and the dealers / Modern are not very helpful so far in checking for potential defects or offering replacements. Current tractor and bush hog are still solid. No shear pins broken. Current blades are number 401-0056S. They're all that's available locally (Southeast Texas). Used these since the tractor and bush hog were new with no issues like this.
Does anyone know of some heavier duty alternative blades that they can recommend and will fit?
   / Heavy Duty Bush Hog Blades #2
What you describe sounds like a fatigue failure point. If you have a needle scaler use it full power on both sides of the blade, esp the edges, in the region that is failing. -- This effectively puts the surface of the metal into compression and makes it much harder for a crack to start.
2016 Toro Groundsmaster 7200 Zero Turn Mower (A54811)
2016 Toro...
(2) PALLETS OF TRAILER JACKS & MISC TRAILER PARTS (A54756)
(2) PALLETS OF...
1985 Miller Wildcat 350-D Welder (A54811)
1985 Miller...
(APPROX 104) 2X4X10 PINE LUMBER (A54756)
(APPROX 104)...
UNUSED LANDHONOR MAP-16-24W MINI MOUNT PLATE (A54757)
UNUSED LANDHONOR...
2003 Ford F-550 20ft Rollback Truck (A55788)
2003 Ford F-550...
