Heating Problems
   / Heating Problems #1
donniehelms1962
Monroe, North Carolina
Massey Ferguson 1240
Just bought this MF1240 compact tractor. The problem is that the tractor seems to be losing some anti-freeze. Also it seems that it runs cooler since I took off the side panels. But then today the tractor wouldn't switch off. It also lost my gauges, even when I switched it on again. Please help me. This is my first tractor ( a newbie )
   / Heating Problems #2
What are cool and hot? You have a electric problem, most likely fuses or some bad grounding.
   / Heating Problems #3
Loosing anti-freeze is unrelated to electrical problems.
Is it leaking externally? Any drips?
If not: How does the oil look? Any milky-ness or white-ness? Does the tractor smoke when running or when started? What does smoke look like?
Who did you buy it from?
   / Heating Problems #4
Water in the oil? Milky Way candy bar inside color. Oil in the coolant? Streaks and discoloration. You might try a radiator cap replacement and or a radiator pressure test . you can likely get one of those from Autozone under their tool loan program and take it back when you're done. Might not fit though so take cap in to see. Bad radiator caps can piss fluid.
Electrical is totally separate. Clean to bright battery terminals and whatever others you can find. Do yourself a favor when you do it and smear some dielectric grease on terminals. Same with ground. Before doing any of that look for hanging ground wires broken. Check fuses look for bad contacts corrosion. Dielectric grease here too if you can. For all of it to go out it should be a main fuse or breaker of some kind ahead of the fuse box.
2024 JOHN DEERE 1025R LOT NUMBER 109 (A53084)
2024 JOHN DEERE...
2014 ATC TRAILER (A52472)
2014 ATC TRAILER...
2007 KENWORTH W900L DAY CAB (A52472)
2007 KENWORTH...
John Deere Gator Utility Cart (A50324)
John Deere Gator...
Coleman 274BH Lantern Edition Travel Trailer (A51694)
Coleman 274BH...
2013 Ford Edge SEL SUV (A51694)
2013 Ford Edge SEL...
