Heater
/ Heater #1
urd505
Kubota L4200GST
L4200 Cab..heater putting out cool air...any suggestions,thanks
/ Heater #2
The shut off, inline water valve, is not open....
Kinked heater hose, (No water getting to heater)...
Very low on engine coolant...
Water pump having problems getting the water to the Top of cab,
Thermostat stuck Open, Engine itself is not hot enough, to give you a good heat transfer at the heater, WHAT IS THE ENGINE TEMP READING?...
On my L4200 cab... I block the radiator air flow, slip a piece of cardboard or rigid plastic sheet into the slot that was designed for the filter screen...
The engine will run at a better temp during the winter & the Heater will get you Very toasty inside the cab... KennyV
2020 TROXELL CONCEPT 130 BBL STEEL VACUUM TRAILER (A63569)
2020 TROXELL...
2020 ISUZU NRR 4X2 S/A 22FT BOX TRUCK (A59912)
2020 ISUZU NRR 4X2...
2015 FORD F-350 XL SUPER DUTY 12' BOX TRUCK (A64280)
2015 FORD F-350 XL...
2022 FORD TRANSIT 250 CARGO VAN (A59905)
2022 FORD TRANSIT...
Altec Digger Derrick Hydraulic Boom (A61572)
Altec Digger...
more info coming soon! (A61569)
more info coming...
