Heat Guage
   / Heat Guage #1
Lem
Bronze Member
Fries, Va.
Kabota RTV 500
I have a 1993 John Deere 870 with under 300 hours and the heat guage works occasionally and I have checked where it hooks to the top water hose for a good connection. Any Ideas?
   / Heat Guage #2
I’d try making sure the ground is solid first, then maybe a sender or gauge
   / Heat Guage #3
I assume you've checked the radiator level. If it's too low the sensor will not work. If it's right on the edge it can cause your problem. Next, do you own a multimeter? If so you can measure the resistance (Ω) of the sensor. Warm up the engine and when it's working shut the engine off and use the test leads and put one on the wire going to the sensor after removing the wire and the other on bare metal on the engine. You should get a reading, write it down. When it doesn't work do the same test. If you get a similar reading the sensor is fine. If not it's most likely bad. If the sensor is good measure from the wire on the sensor to the negative terminal on the batter (assuming it's a negative ground system). If that reads fine find install the wire back on the sensor and remove the cluster gauge. Find the wire coming from the sensor and measure it again after disconnecting the gauges and measure the sensor side again. If it reads fine plug everything back in and start the tractor. If it works now you might of just had a bad connection. If it doesn't most likely it's your gauge cluster.
2011 GALYEAN 130BBL VAC TRAILER (A52472)
2011 GALYEAN...
2019 FREIGHTLINER CASCADIA TANDEM SLEEPER TRUCK (A54607)
2019 FREIGHTLINER...
2017 TROXEL 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2017 TROXEL 150...
Tennant 800 Ride-On Street Sweeper (A55787)
Tennant 800...
2006 V.E. ENTERPRISES 130 BBL STEEL VACUUM TRAILER (A53843)
2006 V.E...
20" Sea Container (A47384)
20" Sea Container...
