Hearing Protectors Over Glasses????
   / Hearing Protectors Over Glasses???? #1
40_acre_mule
South Mississippi
Kubota L4701
Does anybody make hearing protectors that have a notch for my safety glasses side pieces (temples)?
My safety glasses have pretty thick temples and when I put the muffs on, I don't get a good seal right at the front of the ear.
   / Hearing Protectors Over Glasses???? #2
I've never seen such an item. I wear the Peltor Worktunes over my glasses but the temples are pretty thin. No problems. You may have to use the foam, in-ear plugs if your glasses are too bulky.
I do get some minor pressure related pain after a long time but I try to shift them around a bit now and then.
   / Hearing Protectors Over Glasses???? #3
I have the glasses that loop around my ears. Thin and do not cause any problems. I also use ear plugs with the ear muffs. I figure the muffs give me 15 and the plugs give me 15, so I get around 30 decibel drop with the combo.
Bob
   / Hearing Protectors Over Glasses???? #4
Yes.. Just about any set of ear muffs made for shooting will have notchouts or clearance for safety goggles. i have some remingtons.. that were 30$ each.. but I've also picked up generic brands from milsurp places.. army/navy / pawn shop and sporting good stores int he 6-15$ range that had clearance for goggles.
Soundguy
   / Hearing Protectors Over Glasses???? #5
   / Hearing Protectors Over Glasses???? #6
"When both a muff and ear plug are worn together, OSHA allows 5 dB to be added to the higher of the two NRR's (refer to Tech Brief 90-03,"
So an ear plug with a NRR of 25, plus an ear muff with a NRR of 20, equals a combined NRR of 30, not 45!
I find the best sound reduction is an ear plug. Goes up to NRR 33. I do notice the difference once the NRR's change by about 2-3, which is consistant with the physiology of the ear. Sopme people will hear a volume difference of about 1, most will hear a dB difference of 2, and most will perceive a 3 dB increase as twice as loud. The dB (deci-Bel) is a logarithmic ratio.
   / Hearing Protectors Over Glasses???? #7
Wow, good information. Thanks. Even 5 dB is a lot.
Bob
   / Hearing Protectors Over Glasses???? #8
jayhaitch I find the best sound reduction is an ear plug. Goes up to NRR 33. [/quote said:
Do you have favorite ear plug brand? Which one goes to NRR 33?
Bob
   / Hearing Protectors Over Glasses???? #9
At work we use 'max lite' ( Howard Leight ).. and they have a NRR of 30.
Soundguy
2003 Pierce Tilt Cab Foam Pumper Fire Truck (A51692)
2003 Pierce Tilt...
2007 IH 4300 Dump Truck (A47384)
2007 IH 4300 Dump...
2006 HAMM 3205 SMOOTH DRUM ROLLER (A51246)
2006 HAMM 3205...
(10) 24' CORRAL PANELS (A51247)
(10) 24' CORRAL...
UNUSED JCT 72" HD BRUSH CUTTER (A51248)
UNUSED JCT 72" HD...
2014 International PayStar 5900i S/A Flatbed Truck (A52377)
2014 International...
