Hearing Assistance
   / Hearing Assistance #1
Guywire
SLO Co, Calif
NH TC-30 & MF 3165
I have an NH TC-30 w/box blade. I've set up a mickey mouse version of DraftHorse's level (thank you DraftHorse - http://www.tractorbynet.com/forums/...renching-maintaining-slope-2.html#post1768815) on it (mickey mouse because I don't weld - among many other things).
It works adequately for me, but I have difficulty hearing the laser detector on the box blade. With my far less than perfect hearing and a diesel engine in front of me, I have to turn at least half-way or more around to hear the beeps. Between not watching where I'm going and playing with the 3ph, I tend to wander the tractor around.
Does anyone know of any wired/wireless speaker & mic systems that I can mount the speaker in front of me and the mic affixed to or near the detector?
   / Hearing Assistance #2
Not sure if this will be of help but I have a couple of these and they work well for my applications...
I am not familiar with the "beeper" on your device but if it can be disconnected and replaced with a 1/8 modular (typical earphone) plug...it should work...
Mini Audio Amplifier - RadioShack.com
Certainly an option, but my problem is that whenever I open an electronic case, things just don't seem to fit back into it again. :ashamed:
   / Hearing Assistance #4
How about getting a pair of walkie talkies (kind with earphone/headphone jack) and the accessory headphone/mic. Rad Shack has both of these for $20 each. I have used a system like this to make communicating with my helper/spotter (wife) easier with the tractor running.
radios
Motorola Talkabout® FV300 2-Way Radios (Pair) - RadioShack.com
headphone/mic
Headset for FRS 2-Way Radios with PTT and VOX Capability : Radio & scanner accessories | RadioShack.com
When using the laser system setup one radio to talk and you just listen on the other end.
radios
Motorola Talkaboutョ FV300 2-Way Radios (Pair) - RadioShack.com
headphone/mic
I just went with /Pine's suggestion, though with a microphone at the laser receiver and a mic extension cord.
I do have some personal 2-Way radios that we've been known to use on our small (5 ac) property, but they kind of seem like overkill to get sound five feet closer to me. :)
Thank you for the suggestion, though.
(1) HD 24ft Free Standing Corral Panel (A51573)
(1) HD 24ft Free...
RoGator RG1100C (A53472)
RoGator RG1100C...
2018 Ford F-150 Ext. Cab Pickup Truck (A51692)
2018 Ford F-150...
2012 MACK GU713 DUMP TRUCK (A51406)
2012 MACK GU713...
2020 CASE IH 110N LOT NUMBER 222 (A53084)
2020 CASE IH 110N...
New/Unused 48in Quick Attach Pallet Forks (A51573)
New/Unused 48in...
