Hearing a ticking noise for the rear end of 3320
   / Hearing a ticking noise for the rear end of 3320 #1
sparker133
Green bay, Wi
2013 Deere 4320 cab, 180 loader, 485 backhoe, 2021 Deere 1023e, Vermeer trencher, 2022 Deere 26g
After the using my 3320 for a while i start to hear a ticking noise in the rear end. The other day i graded my mile of road half way through it started, also when you look a the back there was some fluid leakage. Is there a serious problem it only has 105hr on the machine.
   / Hearing a ticking noise for the rear end of 3320 #2
Where is the leak coming from?
no it is not under warranty anymore
   / Hearing a ticking noise for the rear end of 3320 #6
Those kinda things get to me ... a ticking, clinking, rattle ... I hate em.
   / Hearing a ticking noise for the rear end of 3320 #7
Been using the diff lock?
And for sure, as RickB suggests, check the bolts. A ticking noise is not good and should be found before something worse happens.
   / Hearing a ticking noise for the rear end of 3320 #8
PR or hydro? The PR's are very noisy & nothing to worry about (except the leak that is).
it is a ehydro
   / Hearing a ticking noise for the rear end of 3320 #10
With such a low hour machine, it's probably best to ask your dealer to send a tech.
The clicking might be nothing...might be the differential (as beenthere wrote, have you been using the differential lock much?).
You need an expert to advise you...and we're good, but we're not at your house to listen to the ticking noise.
John Deere Quick Hitch (A50121)
John Deere Quick...
80in HD Tooth Bucket with Side Cutters (A52748)
80in HD Tooth...
(4) Gladiator 12-16.5 Skid Steer Tires (A50121)
(4) Gladiator...
2018 KENWORTH T370 T/A DUMP TRUCK (A51406)
2018 KENWORTH T370...
2011 Ford Crown Victoria Sedan (A51694)
2011 Ford Crown...
