Heads up
   / Heads up #1
jfh28
Platinum Member
Poconos, PA
Power Trac 2425
Was just out in the garage getting the PT ready for the upcoming snow storm.......chains on the tires....lube......rubber mat on the plow......and I kept getting a whiff of something burning. I had the garage door open so I thought it was coming from outside somewhere......kept checking and couldn't track it down. Finally came time to check the air filter and oil levels so I swung the seat off the engine compartment and saw the compartment full of crispy leaves! I have no idea how or when they got in there but that was a disaster waiting to happen! So now that fall is over and snow is on the way go out and check your engines for stray combustibles......haha.......Jack
   / Heads up #4
Good point! I use my 422 a lot in the yard, cutting grass and mulching leaves in a 3 acre area. I NEVER put her away after a job w/o hitting it with the leaf blower...front to back and everywhere in between that I can get at.
   / Heads up #5
I googled PT and came up with a PT cruiser but I do not think this is what you mean.
   / Heads up #6
I looked at your info and see power trac 2425. What a neat little contraption!
   / Heads up #7
Do you run chains on all four tires. Do they rubon the frame.
   / Heads up #9
I haven't named my PT. My kids named our red Suburban 'Clifford', though. :laughing:
   / Heads up #10
I run chains on all 4 wheels on mine. Clearance was always an issue. Some that flip their wheels have more clearance. When JJ was kind enough to let us know about a great deal on tires and rims for my tractor, i bought some and then made adapter plates so that I could use them as singles on my tractor (tractor is setup for duals) with much greater clearance than the factory setup.
Ken
2013 Ford Escape (MPV), VIN # 1FMCU0F77DUB50591 (A51572)
2013 Ford Escape...
Electric Mobility Scooter (A51694)
Electric Mobility...
UNUSED CFG HANG-ON PALLET FORKS (A51248)
UNUSED CFG HANG-ON...
2013 Dodge Charger Passenger Car, VIN # 2C3CDXAT8DH646721 (A51572)
2013 Dodge Charger...
BAUMA LIGHT TX 12 LOT NUMBER 240 (A53084)
BAUMA LIGHT TX 12...
