nmu98
Veteran Member
- Joined
- Jun 1, 2007
- Messages
- 1,132
- Tractor
- JD 5203, JD 3720, JD 4110, JD 445, IH 1586, IH 886, IH 404......
I bought a Deere 673 Tiller at the beginning of the season to replace a Frontier model I was going to store at a different location. When I brought it home from my dealer, he told me it had a manual chain adjuster and the manual said to check it after 500 hours. we talked about how to check it without taking off the cover and he said it was easy... Blah.. blah...
I have a very good dealer.. but..
So I assumed it was adjusted correctly
. I used it for the season, maybe 30-40 hours. while i was cleaning it up to be put away for the season, i noticed the oil in the sight glass was dark. Since i was using a lot of water to get the dirt off the under side, I thought I would change the oil incase I got water in it.... It was never dark before, so As I pulled off the cover, the oil came out, pretty dark, with no water, and some normal chain metal wear.
To my suprise, the chain tensioner was not even close to the chain. In fact, there was absolutly no way, even if the chan was completely tight on the gears that the tightener would have touched. I adjusted the tightener 3 inches in to factory specs, and there is a huge difference in how the tiller runs.
Prior tot he adjustment, I could move the tines about 3-4 inches. I thought it was PTO slop. It was not, it was the chain slop. There is very little movement in the tines before the PTO shaft moves. Check them!
My Frontier has a very poorly designed spring auto tightener.... But at least you know there is there and working...
