Heads up...L,M,H shifter
   / Heads up...L,M,H shifter #1
duffer
Platinum Member
Aiken, SC
'16 Mahindra 2538
Had a strange thing happen today on my 2538. Tried to shift from High to Medium mode on my Hydrostat, and the gear shift lever came off in my hand...WTF???
Naturally, I was away from my garage, but luckily I had a small tool box on the tractor. Turns out the bolt that acts as a pivot point, came out. Fortunately, the bolt stayed in the shifter. Unfortunately, I had to crawl under the tractor on some pretty uncomfortable gravel, and try to re-insert the bolt and tighten it. Took about 10 minutes to finagle it back in, but it shifts much easier now that the bolt is tight.
For those of you that have a "hard to shift" mode handle, you might want to check to see if the bolt is tight on your machine. Hope it is.
Just FYI...
2022 Chevrolet Tahoe FL SUV (A48082)
2022 Chevrolet...
2021 CATERPILLAR 259D3 SKID STEER (A51242)
2021 CATERPILLAR...
2010 Ford Crown Victoria Sedan (A48082)
2010 Ford Crown...
2007 Case IH 8010 4WD Combine (A50657)
2007 Case IH 8010...
GARDNER DENVER 480 VOLT AIR COMPRESSOR (A50854)
GARDNER DENVER 480...
2016 International ProStar 122 T/A Sleeper Cab Truck Tractor (A48081)
2016 International...
