Headlights will not work
   / Headlights will not work #1
LLIHKAO
cobden
1953 Ford Jubilee
Concerning my 1983 John Deere 750 compact tractor, my hazard, work, and tail lights all work perfectly but my headlights will not work. The sockets each have two contacts and I have power to one of the contacts in each socket but no power to the other contact in each socket. Any ideas as to why the headlights won't work? Also, there are three wires going into each socket, two smaller and one bigger wire. What are these designated for? Thanks.
   / Headlights will not work #2
Well I'm only guessing but two of the wires should have power. One wire on high beam and the other wire would be low beam. The third wire going into the socket is for the outer shell of the socket which would be ground.
Are the bulbs good? If you have power but no lights it's either the bulb or no ground.
   / Headlights will not work #3
Also check your fuses. If there is a separate one for the headlights, it might be loose or blown. A test light will help you find your problem quickly, if you know how to use it.
i believe my sockets are not connected right, especially the ground for the bigger wire and the hot for the 2nd contact in the socket. i will try it tonight but i beleive you are on the right track with this. thanks.
yes they did. they stopped working after another person installed and begin using external headlights instead of the factory headlights.
   / Headlights will not work #7
Follow the original light harness back to the frame area, to see it was unplugged at some point. Do you have and know how to use a test light ?
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A55315)
NEW HOLLAND 706 30...
2020 DRAGON ESP...
2006 Sterling Acterra Rollback Wrecker Truck (A59814)
2006 Sterling...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
*Selling at Royal Auction Tampa, FL Location* (A59228)
*Selling at Royal...
FENCE PANELS (A58214)
