Headlight Bulbs!! Good Ones Finally!
   / Headlight Bulbs!! Good Ones Finally! #1
nspec
Platinum Member
Southern Rhode Island
Kubota B2630, '53 Farmall Super H, '47 Farmall AI, '44 Farmall A
After playing around a lot and reading even more, I've finally gotten a decent headlight bulb. Kubota B2630 - standard dynamo. Came with 1073 bulbs @ 23w each. Very dim yellow light. Upgraded to a 795 bulb @ 50w each. I had no heat problem, but I wanted to add a rear worklight. No way could I run the headlights, worklights, and flashers without putting a drain on the battery even with the rpm's up. Tried a couple of led bulbs - they sucked.
Solution - Sylvania Silverstar 1156 ST bulbs. They are 26.9w each and only 7.99 at Auto Zone - for 2! The glass on the bulb is pale blue. The light is very bright and crisp white. Very noticable difference. Comparable to the 50w 795's but a whiter white. I'm sold. Highly recommended to all those with headlight woes.
   / Headlight Bulbs!! Good Ones Finally! #2
Thanks for posting. I'm gonna have to book mark this for when it's time to replace mine. They're ok for now, but when the time comes, brighter is always better:D.
2018 FORD F-150 XL CREW CAB TRUCK (A51406)
2018 FORD F-150 XL...
2023 Ford Explorer AWD SUV (A51694)
2023 Ford Explorer...
1997 John Deere 8100 MFWD Tractor (A52748)
1997 John Deere...
2019 Tico Yard Spotter Truck - Cummins Diesel, Allison Auto, Hydraulic Air Fifth Wheel, Cab w AC (A52748)
2019 Tico Yard...
Diamond 5' Heavy Duty Excavator Mower (LIKE NEW) (A50774)
Diamond 5' Heavy...
2020 New Holland 105 Workmaster MFWD Compact Tractor with 632TL Front Loader - Poultry Special (A52748)
2020 New Holland...
