Head Replacement
   / Head Replacement #1
itcametopass
Greensboro, NC
Yanmar 2210
I have a YM2210 that I recently replaced the head that had become cracked due to overheating. I replaced it with a rebuilt unit I ran down. I ran it for about two hours finish mowing & put it up. The Temp for most of the time was in the 190 - 205 range with the new temp gauge I installed. When I started it again I noticed a bit of smoke leaking from between the head & block. /forums/images/graemlins/confused.gif I ordered another head gasket to replace the new one I just put in two hours of running ago.
I want to confirm the torque for the head bolts and see if anyone has any other ideas of things I need to look at when I take it down again.
Once more, Thanks for the help in advance.
   / Head Replacement
The replacement head was supposed to be in good condition. What is the correct bolting order? I followed a tightening pattern. I want to make sure it was the correct one.
2008 JLG SKYPOWER 800AJ MANLIFT (A51246)
2008 JLG SKYPOWER...
RYOBI 2900 PSI GAS PRESSURE WASHER (A51248)
RYOBI 2900 PSI GAS...
UNUSED FUTURE FT1000J SMOOTH DOUBLE DRUM ROLLER (A51247)
UNUSED FUTURE...
2012 Hyundai Genesis Sedan (A51694)
2012 Hyundai...
10' CONTAINER (A51248)
2013 F-550 Bucket Truck (A53472)
2013 F-550 Bucket...
