Head gasket
   / Head gasket #1
Gizmo36
Platinum Member
East of Duewest S.C.
I put a head gasket on my 1700 today when i got done water was coming out the side of the block .How do you tell what side is up. it said in the book to put ( side with stripes should be visible ) but there was no stripes. I call the parts place were i got it and they were not sure .
   / Head gasket #2
I never put one on a Yanmar, but on all others, if all holes, etc., lined up, it always worked, with proper torque.
   / Head gasket #4
If you have the correct gasket for the YM1700 it will only line up one way. Take the head to a machine shop and let them check to see if it is warped, if it is they may put it on a surface grinder and get the warp out. The head bolts on the YM1700 should be torqued to 130 ft lbs + or - 3.6 ft lbs.
Danny
P.S. is this one of the after market gaskets
   / Head gasket
But both sides were not made the same.And i did not know which side went up. and it would go either way.I got it from a dealer on here.But i did not want to say that.
   / Head gasket
I need to get a new one .but I want to know which side is up before I put it on.
   / Head gasket #8
I would PM the dealer to make sure... He may be using a different head gasket than some other guys atr familliar with..
   / Head gasket
I email the Dealer to see what he had to say.but i called down there yesterday and the one i talk to was not sure. That is why i came on here .
   / Head gasket #10
</font><font color="blue" class="small">( I never put one on a Yanmar, but on all others, if all holes, etc., lined up, it always worked, with proper torque. )</font>
There in lies the problem, hole alignment. Small engines are not too bad but as more cyl get added the harder it is to catch a misaligned or missing hole.
Son bought an old Land Cruiser last yr with about 50 mile on the engine but the valve train was bone dry. These old engines were copies of old Chevy 6's. Lots of holes, all but one small hole were sym. The one hole/passage was the oil hole to the valves. Also seem to remember the oil passage took a jog in the head gasket. Oil passage was not same location in block and head.
really gotta look closely.
2020 CHEVROLET 2500HD CREW CAB TRUCK (A51406)
2020 CHEVROLET...
2020 Ottawa T2 Spotter Truck (A52384)
2020 Ottawa T2...
2017 Snapper Pro 48in Zero Turn Commercial Mower (A51691)
2017 Snapper Pro...
JOHN DEERE 7300 LOT NUMBER 18 (A53084)
JOHN DEERE 7300...
2021 Mercedes-Benz Sprinter 4500 (A51692)
2021 Mercedes-Benz...
Toro Workman 175 Sprayer Cart (A50324)
Toro Workman 175...
