head gasket needing replaced?
   / head gasket needing replaced? #1
Ginormous
Dayton, Ohio
Yanmar YM2210
Hi guys,
It looks like I have another problem that may also be contributing to making my tractor being hard to start. I noticed coolant seaping out of the head gasket seam. It's very slow; no puddle under the tractor, just a small number of drops that got the concrete wet plus some drips hanging on the bottom of the crank case bolts. It's very clear that coolant is coming out of that seam (driver's side?) underneath where the thermostart connects to the engine -- I should post a picture for posterity. Is this the classic way a head gasket starts to fail?
G
   / head gasket needing replaced? #2
I was told to check for head gasket failure by starting the engine, and after it first starts up to check the radiator overflow bottle for air bubbles coming from the tube inside the bottle.
I have had head gasket failure twice (both times from "operator error") and both times saw bubbles in the overflow bottle upon starting.
Good luck!!
   / head gasket needing replaced? #3
No doubt you have a head gasket leak. I wouldn't call it the classic way, rather Stormpetrels would be the classic way. Head gaskets can leak into different areas. If you do the test Stormpetrel described that will pretty much tell you whether combustion is leaking back into the cooling system. If you don't show bubbles there you might try re-torquing your head bolts. Might possibly stop the outer leak. If you are getting bubbles I would recommend a gasket change.
   / head gasket needing replaced? #4
Clean the area well, and assure it is a HG leak. Very strange that a HG would seep to the outside and coolant reach the ground without drying from hot engine. Mine has shown a slight coolant discoloration at the head/block seam for 13 years, but have never actually seen coolant.
I was suspicious a few weeks ago because I found the radiator overflow bottle was empty. I checked the radiator and it was full. I refilled the overflow bottle and cleaned off the side of the block because I had spilled some coolant while filling the bottle and went around wiping things off. When I went out this weekend to push snow, I could see coolant clearly coming from the gasket and streaking down, so it leaked out slowly over time in cold temperatures. The overflow bottle looked about as full as it had been. I think I may have seen some white smoke on startup too, so it's probably leaking inside somewhere too. I will definitely check for bubbles in the overflow bottle the next time I start it up.
So I finally took a picture. Can someone confirm, is the red arrow pointed at the head gasket seam? This is where I have the antifreeze leaking out. Where are the bolts to tighten this down, is the blue arrow one of them? Anyone know what torque this (and the others) should be at? Thanks!
G
   / head gasket needing replaced? #7
Unfortunately tightening it may make it worse. You cannot only tighten one side as this could warp the head. A mechanic like myself would not charge a whole lot to change the head gasket on your Yanmar engine as opposed to a car or truck.
Stop leak etc will not help only harm. Any further questions I can surely help you!
   / head gasket needing replaced? #8
Yes, that is the head gasket. Yes that is a head bolt. you have six of them, 3 on each side. Torque is 133 ft lbs + or - 3.6. I doubt you will move it with the torque wrench set at that. However, if you do I don't think you will warp your head. If you do I refuse to be held accountable. :D I do doubt torquing it will stop the leak but I sure don't know.
   / head gasket needing replaced? #9
If that engine is designed similar to YM2000 you have to look down into the intake manifold to see the next head bolt.
I was wondering where the other bolts were! So does that mean I need to take off the intake manifold to get to the head bolts? How much stuff can I leave connected to the head when I take it off? I'm wondering what other gaskets I may need and if there are any special tools I need.
diesel lover -- thanks for the advice and encouragement. I split my lawn tractor B&S engine a couple summers ago because there was a gasket around the waist of the engine that was leaking oil. It wasn't too bad, but there were lots of things to remove and later re-attach.
G
2023 NEW HOLLAND HYDRAULIC THUMB FOR B95D TLB WITH STANDARD STICK (A53472)
2023 NEW HOLLAND...
2015 GMC SIERRA 2500 SERVICE TRUCK (A52576)
2015 GMC SIERRA...
VERMEER RTX130 WALK BEHIND TRENCHER (A51242)
VERMEER RTX130...
2014 Jeep Compass 4x4 SUV (A51694)
2014 Jeep Compass...
Ingersoll Rand Air Compressor (A51573)
Ingersoll Rand Air...
2009 MACK GRANITE (A52472)
2009 MACK GRANITE...
