Hdro fluid levels
   / Hdro fluid levels #1
Bubba Tex
Bronze Member
Boerne, TX
JD 2305
Fellas,
I have the 2305. To check the fluid levels you use the little sight glass which is on the back of the tractor where you have to practically stand on your head to see it. My question is: What position should the FEL and 3PH be in when checking? When all of the rams are extended, i.e. with the bucket in the full dump position resting on the ground, the level seems low, but if I park it with the bucket level on the ground it looks fine.
   / Hdro fluid levels #2
I have a question, does it get checked cold or just after running it ? I think it would be different
   / Hdro fluid levels
I generally check cold, before startup as part of my PMI. Guess that leads to the question; What position should the FEL be in when parked?
   / Hdro fluid levels #4
FEL and 3PH should be all the way down, and checked cold as per my 4110 manual.
   / Hdro fluid levels
Got it, I always park with both ends lowered. Should the bucket be in the full dump position, ("upside down"), or with the bottom of the bucket flat on the ground?
   / Hdro fluid levels #6
I do not think the curl cylinders hold enough fluid to matter, but I just put the bucket flat on the ground like a always park it anyway.
   / Hdro fluid levels #7
I have a new 2305 and I noticed that same thing, when running the tractor or pressure in the FEL lines the sight glass shows no fluid but when the FEL is down and the machine is off, I am at about 1/2 on the sight glass.
I wanted to buy a quart of fluid to top it off when needed. The manual states that the fluid from the factory was J20C. My dealer only has the low-vis J20D. Can I top off the factory-filled J20C with J20D low-vis or should I try to find the J20C?
Thanks.
Mark
THREE POINT MAINTAINER BLADE (A58214)
THREE POINT...
DEVELON DL250-7 WHEEL LOADER (A59823)
DEVELON DL250-7...
2017 Chevrolet Tahoe, 179,380 Miles, Decommissioned Law Enforcement Vehicle (A56438)
2017 Chevrolet...
2020 FREIGHTLINER CASCADIA 126 SLEEPER TRUCK (A59575)
2020 FREIGHTLINER...
2020 DRAGON 150BBL ALUMINUM (A58214)
2020 DRAGON 150BBL...
SULLIVAN PATEK AIR COMPRESSOR (A55745)
SULLIVAN PATEK AIR...
