Hazard Light switch
   / Hazard Light switch #1
Whiteclover
Ontario, Canada
Kubota BX25
Has anyone had to change a light switch on a Kubota BX25? The Hazard lights do not work on my 3 year old tractor. Fuses are good and all other functions of the switch work fine. If you jiggle the lever on the switch the hazard lights will work for a few seconds and then stop again. Looks like something is gone or broken inside the switch itself. The tractor is kept outside so it's possible that water may gotten into the switch.
Any advice on how to remove the switch would be appreciated.
   / Hazard Light switch #2
I have no idea if they use the same switch in the BX25 as on my BX2230. If I recall on mine, there were just plastic tabs on either side and once I squeezed them it came out the top of the dash. The wires were pretty short though so it was a pain. Once I to it out, I discovered I could take the switch apart and found that there was a metal bar across the rocker switch and it just got flipped on its side. I turned it back the right direction and put it back together and it works fine. Good luck!
Sent from my iPad using TractorByNet
   / Hazard Light switch #3
Occasionally my lights don't want to turn on, but some jiggling of the switch solves that.
1992 TIFF Motorhome (A50324)
1992 TIFF...
IF YOU BID ON AN ITEM YOU MUST PAY FOR IT!! NO BACKING OUT AFTER IT IS SOLD!! (A50774)
IF YOU BID ON AN...
ASV POSI TRACK RC 100 R-SERIES SKID STEER (A51242)
ASV POSI TRACK RC...
2018 Ford Fusion Hybrid Sedan (A50324)
2018 Ford Fusion...
2017 Ford F-450 Crew Cab Mason Dump Truck (A50323)
2017 Ford F-450...
