Haying With a B8200
   / Haying With a B8200 #1
b8200hst4wd
Bronze Member
Jordan NY USA
Kubota B8200 HST 4WD
I was wondering if B8200 HST 4WD could pull a fully loaded hay wagon across fields or do you think it might spin and bog down
< I have Turf Tires>
   / Haying With a B8200 #2
<font color=blue>...wondering if B8200 HST 4WD could pull a fully loaded hay wagon across fields or do you think it might spin and bog down...</font color=blue>
Well Alex... you hooked me... /w3tcompact/icons/smile.gif
To put things in perspective... I'll give you my take on a likely scenerio...
Your B8200 is about the same weight as a BX2200...
if you were hooked up to a hay wagon loaded with hay weighing a few tons and facing downhill... I'm sure it (everything- tractor and all) would start rolling.../w3tcompact/icons/blush.gif
Now, after a few moments with a little momentum... the hay wagon will be passing the tractor... then dragging the tractor behind... (you've heard of the tail wagging the dog...)
Now, the driver had better be ready to leap or go with a rolling tractor down the hill...
This is another reason for the bulk weight of a larger utility tractor used in haying... besides the greater PTO hp aspect...
So Alex... when do you start haying with your B8200...? /w3tcompact/icons/wink.gif
2013 Ford F-550 4x4 Ext. Cab Auto Crane 6406H 6,000LB Crane Service Truck (A50323)
2013 Ford F-550...
2015 Chevrolet Tahoe SUV (A49461)
2015 Chevrolet...
RIGID TOOLBOX (A50854)
2017 POLARIS RANGER 570 4X4 PROSTAR UTV (A51406)
2017 POLARIS...
Husky GHM105890 Cement Mixer (A49461)
Husky GHM105890...
2013 GMC Sierra 2500HD Ext. Cab Pickup Truck (A49461)
2013 GMC Sierra...
