Haying quandries
   / Haying quandries #1
xmariner
Bronze Member
Bushnell, FL
LS XR4155HC
Besides drying - what is the most important phase in haying?
   / Haying quandries #2
Keeping all your junk working properly and hope none of it breaks down when it's going to rain tonight :laughing:
Like you said, make sure it's dry, the rest will come to you. Unless you have some really new(ish) equipment, having a backup plan, like a neighbor you can call on with hay eqip. in the event of a breakdown. The trouble is when your weather & hay is ready, so is your neighbors.
   / Haying quandries
I couldn't agree more Rusty. If I had neighbors with equipment... Of the 4 basic steps; cutting, tedding, raking and baling - do you have any thoughts as to which if any plays a pivotal role?
   / Haying quandries #5
The most important part of haying, is the money it takes to buy the equipment. Have you priced equipment lately?
100hp tractor 65K
kuhn disc cutter 12K
rake 7K
Baler 40K
And it doesn't last forever. Figure on replacing it every 12 years or sooner if your in business.
   / Haying quandries #6
Getting it all done before the rain is the most important part. I check the weather forecast almost hourly before I make hay and after I have started. OK ok maybe not hourly but several times a day. I'll also throw in there to make sure the dew is off the hay before you touch it or you can really foul things ! Start your equipment prepping asap and don't cheap out on repairs. They WILL haunt you at the worst time
   / Haying quandries #7
The most important part is knowing when to cut and cutting then. Old hay is better than a snow bank for feed but not much. If the hay is to young when you cut it you get less and don't get the feed value.
The second is getting it to the correct dryness when you bale. Many people think hay should be dry as dust when the bale but it should have some moisture in it or you loose the leaves and have nutrients bleached out by the sun. Of course you have to have it down so that it does not mold as well. Ed
   / Haying quandries #8
Help us out here. Are you asking for experience because you're looking at buying your own equipment, or are you already haying and maybe you're struggling with getting it right?
To produce high quality hay, there's a lot involved.
Some important steps begin way before you bale any hay:
Soil test
Fertilizer (and lime, if needed)
Renovating the soil. (sub-soil plowing)
Weed control
And, then, after you bale, where will you store it?
   / Haying quandries #9
weed control, fertilizer, and following NOAA area weather discussion to check for good weather.
   / Haying quandries #10
I think so much of it depends on why your are doing hay and on what scale.
I honestly had no idea haying was so difficult until people on this forum told me it was!!!
To clarify, I only do hay for my cows and my dad's cows. My entry cost was pretty small - I already had my DK 45, so I bought an old New Idea roller ($3800), a NH 256 rake ($600) and John Deere 24T baler ($900) and Kuhn GMD500 disc mower (traded two calves for it).
I only cut, rake, bale - no tedding. However, I only do 250-350 rolls and a 500-1000 squares per year, so as far as the hay business goes, I'm pretty small time. However, if I was looking to produce high-quality hay for a different market (I'm thinking horses), there would be a lot more involved and a lot more in play.
When I cut hay and it gets rained on, I wait until it dries and roll it. I have yet to receive a complaint from the cows.....
Good luck and take care.
(4) Stand Alone Texas Panels (A50515)
(4) Stand Alone...
1996 Elgin Pelican Series S Street Sweeper (A50322)
1996 Elgin Pelican...
Poly Round Bale Ring (A50515)
Poly Round Bale...
JOHN DEERE 437E KNUCKLE BOOM LOADER (A51242)
JOHN DEERE 437E...
2011 Ford Utility Econoline Van (A50515)
2011 Ford Utility...
PLEASE VIEW ALL PICTURES!! (A50774)
PLEASE VIEW ALL...
