haybob9300 tedder rake flat tire
   / haybob9300 tedder rake flat tire #1
cburke
chehalis, wa
massy ferguson 481
I have haybob tedder rake and have a flat tire. I am trying to take the rim off but cant seem to figure out how to take it off. Do I need to drop the whole shaft that goes up thru the rake. and if so do I loosen the large nut at the top.
   / haybob9300 tedder rake flat tire #2
Hello cburke, No you don't drop the leg. On the opposite side of the axle is a bolt in the centre of the hub. Undo this and it will release the hub cap and tire. You will see what I mean when you have the hub cap off.
Next slide the wheel straight off. NB The bearing are meant to come off as well,as the rim. Often the rim will be difficult, espesially if it has been on for several years. In that case get a large punch (flat face) and tap your way around the hub. Try to avoid damageing the rim or you will have a big file job. Some times the rim will be really stuck and some damage is unavoidable.
Before refitting the wheel clean the axle and put a thin smear of grease on to assist sliding the rim back on the axle and prevent or reduce trouble next time you need to remove the wheel.
LASTLY bolt the hub cap back and REMEMBER the spring washer or the bolt WILL work loose and fall out, along with the hub cap and wheel
2006 CHEVROLET SILVERADO 1500HD (A52472)
2006 CHEVROLET...
2025 New/Unused LandHonor 13,000lb Electric Winch (A51573)
2025 New/Unused...
Baker BFD80 8,000lbs Diesel Forklift (A51691)
Baker BFD80...
New/Unused Quick Attach Auger with Three Bits (A51573)
New/Unused Quick...
Crosley 10ft Hydraulic T/A Dump Trailer (A50323)
Crosley 10ft...
