Hay / Straw
   / Hay / Straw #4
Hay is dried grass and pasture cut and used for animal feed. Thus you can have many different kinds of hay such as timothy, clover or fescue.
Straw is an byproduct of gereal grain production. The dry stalk of a cereal plant, after the nutrient grain or seed has been removed. Usually refered to as "wheat straw" or "rice straw" unless it the only grain grown in the area. In my area straw is understood to be wheat straw as that is nearly the only cereal grown.
   / Hay / Straw
Last summer I bought hay anywhere from 50 cents a bale to $1.75 per bale.
Around here hay is usually cheaper than straw
   / Hay / Straw #7
LBrown59 said:
What's the difference?
Hay is cut when the plant is still growing and "live". Straw is cut after the plant (generally a cereal grain as was mentioned) has grown and has dried down. Hay will have (If it's good hay anyway) some nutritional value. Straw doesn't.
   / Hay / Straw #8
Straw is what is left over when you don't plan your hay just right.
-Mike Z.
   / Hay / Straw #9
In addition to the above, straw is used for mulch for tomatoes and is also scattered or even blown over the ground after broadcasting grass seed. Hay is fed to livestock. Hay can be used like straw but in many cases will have more weed seed in it. Straw cannot be used for feed.
   / Hay / Straw #10
Looks like lots of varying opinions on the difference.
Here's just my $.02...
I was always told that straw is the stock of the wheat plant (I guess other plants too). The wheat head is harvested and straw is the by-product. It has only limited uses, not for feed because the straw is hollow same as a drinking straw. Hay can be any grass,legume, forage. Around here mostly grass (not hollow) and is mainly used for feed.
2018 Top Hat Industries 18FT T/A Utility Trailer (A52377)
2018 Top Hat...
2015 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A53422)
2015 Chevrolet...
Caterpillar 315C L Hydraulic Excavator (A53421)
Caterpillar 315C L...
2015 Ford F-350 4x4 Ext. Cab Liberator 3,200LB 1.5 Ton Crane Mechanics Truck (A52377)
2015 Ford F-350...
1993 Ford F-150 Pickup Truck (A52377)
1993 Ford F-150...
