Dec 14, 2013 / Hay cutter, pros and cons #1 K kwall New member Joined Apr 21, 2012 Messages 5 Location robeline,la Tractor ford I need to get another disc hay cutter can anyone tell me the advantages a trailed cutter has over a 3 point hitch type other than the fact you can use a smaller tractor and the 3 point is cheaper.
Dec 14, 2013 / Hay cutter, pros and cons #2 Tx Jim New Member Joined Jan 26, 2007 Messages 10,274 Location Coyote Flats,Tx Tractor JD 4255/Kubota M7040 HDC Pull type follows contour of ground better plus is a lot easier to attach to tractor than a 3 pt model
Dec 14, 2013 / Hay cutter, pros and cons #3 blueriver Elite Member Joined Oct 4, 2007 Messages 4,821 Location S.E.Oklahoma Tractor JD 5520 Montana 4340 Farmall Super A Montana 5720C Also a cutter on a caddy has a tighter turn
Dec 15, 2013 / Hay cutter, pros and cons #4 B bigbull338 Elite Member Joined Dec 12, 2007 Messages 3,213 Location texas Tractor 7040 HDC 1153 fel i know when we get a cutter itll be on the caddy to cut hook an un hook time.
