Hay bales dusty
   / Hay bales dusty #1
BryanM
Northwest Ohio
John deere 2155, ford 1600
I have not been in the hobby of haying very long. I have been wondering if it was normal to have alot of dust on the bales when you bale? I mean I think I am getting a bit to much dust. Is their something I should look at that might cut down on dust. thanks
   / Hay bales dusty #2
Interesting hobby...Dust happens!
First, What is the soil type? Some is dustier than others. What did you cut it with? Disc mowers stir up some dust, sickle mowers usually don't. What kind of rake are you using? If the tines are hitting the ground it will stir up dust while raking, a rotary will usually cause dust anyway. What are you baling and what's the moisture level of the hay when you are baling? You're going to get some leaf shatter, but too dry and you get a lot. Related to the leaf shattter is the relative humidity when you bale.
If you really want to keep the dust down, spend some more on your hobby and install a propionic acid or Silo Guard applicator on your baler. Then you can bale at almost 30% moisture level....very little dust then.
   / Hay bales dusty #3
Its probably just from the hay being really dry when you bale it. Very low moisture content. If its dust from mold, that will develop after its been in the barn a while.
   / Hay bales dusty #4
Are your sure its "dust" as in dirt? It could be wax from the hay stems that's not been removed by a conditioning process. (That's one thing a conditioner system helps with). Could also be mower teeth, mower reel tines, rake and or baler pickup tines hitting the ground. Clover is a high "dust" wax content plant (alfalfa of course, too). Have a lot of ant hills or moles or woodchucks in you fields?
Applying carboxylic acid ("propionic acid") is usually acceptable to cow outfits, but around here horse people generally don't want it in their hay. Their horses are often too picky and won't feed on it. Try a sample yourself. How about a too much battery acid in your salad. Once your hay has this black mark in the neighborhood, it will be hard to convince buyers to come back to you.
Take a look in your baler in the knotter area and have the "dust/dirt" analyzed. See if it dissolves in water for example. If its dirt, raise your cutter bar and pickup teeth. If its wax, rake it more aggressively. This can spin off the wax more thoroughly. (as well as the nourishment value)...
   / Hay bales dusty #5
No one ever said that farming was not a dirty job.
I have an amusing story. Back in the late 1990's we had a lady customer who purchased a used round baler, rake and a tedder from us call and say she was returning the equipment because it made too much dust. She had purchased the equipment in March and wanted to return the equipment in September. We gave her her all the money back and did not say a word because we sold the equipment the next day for $1,000 more than she paid for it. What makes this funny she had baled all her hay for the season and then wanted to return the equipment. Her neighbor is a good customer of ours and he told us he was baling her hay now. He has a cab tractor and she did not.
John Deere 772-A Grader (A52384)
John Deere 772-A...
2020 FREIGHTLINER CASCADIA DOUBLE BUNK SLEEPER (A53426)
2020 FREIGHTLINER...
2015 JOHN DEERE 544K WHEEL LOADER (A51406)
2015 JOHN DEERE...
2019 MACK PINNACLE P164T DAY CAB ROAD TRACTOR (A51406)
2019 MACK PINNACLE...
2021 MACK GRANITE TRI AXLE DUMP TRUCK (A52576)
2021 MACK GRANITE...
