Hay bale comparison
   / Hay bale comparison #1
Builder
Super Member
East PA or 750 mi. east of a short man named Dar__
Kubota, AGCO, New Holland LB
Approximately how many small rectangular bales does it take to equal a 4' round bale?
Or easier yet, how many round bales would 20 acres of average orchard grass yield during a "typical" yield?
   / Hay bale comparison #2
It all depends on how tight you pack them. Someone who puts up 4X5 bales might correct me but I think they usually come in at 700-900 lbs. I make my small squares 50-60 lbs so that would be about 15 +/-.
I'm not sure where you are located so it would be tough to tell on the average yield for your area.
   / Hay bale comparison #3
Better yet... Builder - how many cutting's would you expect in the area that the 20 acres is located?
First cutting is typically the heaviest (in tonnage) yield and each successive cutting is generally less. That said, the 1st cutting is usually the least valuable (per ton).
The information you're asking for is also available at the local NRCS office. They compile yield statistics for local areas - dependent upon localized soil types and drainage, etc. and forage type.
AKfish
AKfish
We get 2 solid and maybe a 3rd (lighter) cuttings per year. Trying to work a deal where I build a pole barn for hay on the Customer's property, they would allow me to take all hay off the property and use the barn to store the hay cut off their property and some equipment, too. No rent and I keep hay.
   / Hay bale comparison #5
Depends on the growing conditions ... some years with ample rainfall and fertilize it will be so thick you won't believe the production and another year without rainfall ... sorry crop.
I make 4x4's and for example one of my 20 acre fields has done 90 in the first cut and last spring it did 22 bales and only one cutting.
I have unrolled the 4x4's and run them thru the square baler ... average is 10 bales at 50-60 lbs ... so I quess my 4x4's weigh 500-600 lbs.
   / Hay bale comparison #6
Be carefull there and have a good solid agreement. The pole barn is not cheap and about the time you get the hay crop cleaned up, free of weeds and have placed the fertilize is about the time the landowner will decide your making out too good and pull the ground from you.
   / Hay bale comparison #7
we been getting about 15 to 20 square bales per 5 by 4 round bale that has been run through a 554xl like they said when fertilize and rain is good on the orchard grass, wish it was hay balin time now!
   / Hay bale comparison #8
I agree with the hay cutting time ... right now we have been getting regualr rainfall
So tell me how are you doing the unrolling and baling? I took the hyd bale unroller on the 3 point and it's real easy to unroll the bale ... my problem was the square baler wanted to re roll it in front of the pickup and I found myself stopping and hand feeding it in. Didn't like that. Are you unrolling and then re rakeing?
   / Hay bale comparison #9
We shoot for a 40 lb square bale when we are baling hay. With that as a starting point a 4 x 4
round bale at 800 lbs would = 20 40 lb. square bales. Ken Sweet
   / Hay bale comparison #10
Ken ... I don't think my 4x4's weigh 800 lbs ... maybe other grasses than Bermuda and Bahia make them heavier. Maybe I need to weigh one. Around here 50-60 lbs (Squares) are what folks are wanting to buy.
2019 FORD F-350 SERVICE TRUCK(INOPERABLE) (A45046)
2019 FORD F-350...
2012 Cottrell EZ-4807 22.5 Ton Car Hauler Trailer (A42742)
2012 Cottrell...
Large Bucket 84" (A42021)
Large Bucket 84"...
2001 P.J. MFG. CO. GOOSENECK TRAILER (A45333)
2001 P.J. MFG. CO...
2019 Harley Davidson FLHTP Electra Glide Motorcycle (A42744)
2019 Harley...
2019 Honda Pioneer SXS700M2 4x4 Utility Cart (A42744)
2019 Honda Pioneer...
