Hawse Fairlead
   / Hawse Fairlead #1
Deerlope
Veteran Member
Northern, New York
Kubota L3830 03: RTV 900
I need to buy a winch for my RTV and I need to know the difference between a roller fairlead and Hawse fairlead. Could someone please explain the difference in the two? What situations would one be better over the other.
   / Hawse Fairlead #2
Good question. I have seen both and I did a search and my results were one has rollers and the other don't. I would definitely want rollers.
Jim
   / Hawse Fairlead #3
   / Hawse Fairlead #4
Skip, I hope I don't make it on your ignore list but I found this link that may explain that the non roller is $42 bucks and the roller is $115 bucks.
I would still get the roller for the extra $$ and have a way to wind cable on winch level. If your pulling at an angle it will all go on the same place on winch.
enjoy this link
Here on both
Jim
   / Hawse Fairlead #5
Mr. Jimi,
Ebay has 'em all the time (Warn Fairleads ) much cheaper everyday....
Just took a look, and ran across one instantly ...
Item # : 320205286804
Right now, it's going for $ 25.00, but of course, you will have to bid on it.
I purchased one for one of my boys last month for 36.00 plus 8.00 shipping..
$ 115.00 is crazy, but , it's your money ~~~~~
:eek:
   / Hawse Fairlead #6
No worries Jim. Only a couple that know more than they really do made the cut so far.
Excellent feature tho, they can't send your pm's and you don't see the useless post. :)
   / Hawse Fairlead #7
roller for cable, hawse for synthetic winch line
   / Hawse Fairlead #8
A roller fairlead protects the cable more on angle pulls. They will both allow the cable to pile up on one side if you are not careful. If it happens, just pull some cable out and get it straight. A hard pull on bunched up cable will end the cable quicker. You need the hawse on your winch if using a rope. I have even seen plastic hawse fairleads on rock climbing buggies. JC
   / Hawse Fairlead #9
go with the roller fairlead anything that drags something across it will always build up friction and friction causes heat and that tears up stuff. keep the rollers lubed up with some spray on lithium grease. the hawse is really only good to me if your pulling straight on and in most cases your not that lucky to have a striaght on pull when your stuck.
   / Hawse Fairlead #10
When I bought my 8000# Ramsey back in 1990 it came with a hawse head and steel cable. I think that was before the synthetic line was out OR popular. I least at the time I never heard of it then. I still have the hawse because in about 20 years I only use the winch about 5 times. I don't take real chances!!
For my ATV's I did buy a cheap roller off ebay.
A couple links to the multi mount system I built for my atv;s
Good Luck,
Rob
Suzuki - King Quad -MultiMount Winch System
2002 Honda Rancher - MultiMount Winch System
(1) 12ft Tarter Gate (A51573)
(1) 12ft Tarter...
2018 Infiniti QX60 Multipurpose Vehicle (A51694)
2018 Infiniti QX60...
John Deere Gator XUV835M 4X4 Utility Cart (A48082)
John Deere Gator...
2001 Volvo VNL Truck, VIN # 4V4N19JF51N250353 (A51572)
2001 Volvo VNL...
2017 KENWORTH T4 CONCRETE MIXER TRUCK (A51243)
2017 KENWORTH T4...
2000 Ford F-150 Pickup Truck, VIN # 1FTRX17W7YNA75070 (A51572)
2000 Ford F-150...
