Tire Selection Having Trouble Finding R1 Tires
   / Having Trouble Finding R1 Tires #1
Travis_R
Veteran Member
Livingston Parish, LA
Yanmar YM2500
Looking for new R1 Ag tires for a a Mahindra 3510 tractor. It has the Industrial R4s that it originally came with in 2009 (?) and now needing the R1s. Where is a good place to find them? Not having a bit of luck locally at tire places or Mahindra Dealers! Thanks!
   / Having Trouble Finding R1 Tires #2
Specialty car tire stores (Firestone, Goodyear, etc.) can usually order tractor tires with next day delivery.
Shop with your existing tire sizes in hand.
EBay sells tractor tires. One of the best sources for unusual size tractor tires.
   / Having Trouble Finding R1 Tires #3
I have deep tread R4s which I prefer over R1s.
   / Having Trouble Finding R1 Tires #4
Will R1 ag tires fit on the same rim as R4 industrial?
I'm not sure but that's a good question. Guess I'll have to look into that also. Thanks
   / Having Trouble Finding R1 Tires #6
Massey could be different but on my Kubota the Ag tires use different sized wheels. In my case I doubt I could find ag tires that would be the same size as the industrials. So to switch I would have to buy new tires and wheels or find a used set.
   / Having Trouble Finding R1 Tires #7
As Oldnslo mentioned you'll probably need to buy rims for the R1's as they'll be different than the R4 rims.
Here's the tire choices I had on my Mahindra 2615. As you can see each type tire needed a different size rim. Mine had the R4's
Ag front: 7x16
Ag rear: 11.2x24
Lawn/turf front: 25x8.5-14
Lawn/turf rear: 13.6x16
Industrial front: 27x8.5-15
Industrial rear: 15x19.5
What size R4's are on the 3510 now?
   / Having Trouble Finding R1 Tires #8
ag 1 and r 4 use the same wheel
   / Having Trouble Finding R1 Tires #9
What size are your r-4 tires?
2011 Toyota Sienna Van (A50324)
2011 Toyota Sienna...
Informational Lot - Financing (A52128)
Informational Lot...
2018 GENIE GTH-5519 TELESCOPIC FORKLIFT (A51242)
2018 GENIE...
CATERPILLAR 48" QUICK ATTACH FORKS (A51242)
CATERPILLAR 48"...
2007 KUBOTA M5040F TRACTOR WITH LOADER (A51243)
2007 KUBOTA M5040F...
2023 BANDIT SG-75 STUMP GRINDER (A51242)
2023 BANDIT SG-75...
