haven't a clue need help
   / haven't a clue need help #1
hounder
I have a case 831 diesel with a loader "unattached" I need to hook the loader to tractor. several problems here.
1.I'venever worked with any hydraulics
2. the origanal pump on tractor seems very weak"may or may not be"
3. I want ports to the rear and forward aswell to plumb other items
4 how do i select new control valve bank? what size quick fittings are most common? should i try to run off of the original pump,pto driven pump,or belt drive?
my goal is loader permanetly mounted with ability to run all attachments from operators seat. I also want to know the best way to control the grapple on bucket. the three point seems to origanally been designed to have power up and down however only "up" works barely. I also have a backhoe attachment for this tractor so need a" live" supply of pressure to plumb into as needed and would like to have a simple out in rear port for dual actining cylinder on another attachment. I know this is a long list of things but would much rather run everything right the first and last time then have to replace it multiple times getting it right. please bear with me as i can be dense when the occasion warrants
   / haven't a clue need help #2
That's why you are here at the TBN fourum
In what way is the pump "weak"? Symptoms please!
Thats called plumbing!
We need more info about present flow and pressure settings plus type of system...open center or closed center...
Need more info....see above
Need more info see above...belt drive is last option....
It is a long list....doi some home work and get back with more info.....:thumbsup:
   / haven't a clue need help #3
Welcome to the forum. Do I understand that the loader and backhoe you have were not originally for this tractor?
MarkV
as far as weak pump the pressure seems low on the three point lift cylinder. the three point may lift 200 lbs slowly however it has absolutely no down pressure more like a float. it is plumbed out the rear but these connectors build low slow pressure also regardless of rpms. The loader was attached to the tractor at one time but the guy i bought it from had removed it to rebuild the tractor motor. the issue there is the control valves where torn loose some how. the backhoe didn't come with the tractor and is one of the main reasons i'm concerned about flow. I don't really want to go to a pto pump unless required as i have some implements that are pto driven. I guess i am asking for those decision makers i should be looking for and then the steps needed to implement them
   / haven't a clue need help #6
3PT's don't normally have down pressure, however they do float.
I can't be absolutely sure about this right now but the tractor most likely has power don on the three point as it has worked off and on. I don't know if this is a aftermarket cylinder or not. it will put pressure down enough to lift the tractor and high center it if the arms are hooked to a box or other solid object. it isn't constantly available though some times it will push down and others it just settles. the manual has nothing in it . anyway this is how it happens if your pulling a gannon and you push the lever back it lowers it and begains to grade if you push forward it raises the gannon slowly if your on a flat hard surface and you push the lever back wards and hold it will slowly began to lift the rear tires till you no longer have traction. it typically leans to the right with the left tire a inch above ground then the cylinder is fully callapsed . I really don't know if thats putting power ie suction on the cylinder or if something else is occuring.
   / haven't a clue need help #8
Wow, this one is a bit confusing. I don't know the model but agree that very few tractors came with a down pressure on the 3pt hitch. Tractor data shows it as an AG tractor with a good amount of horsepower but only 1550 PSI on the hydraulics. My 21 hp tractor runs at 2500 PSI. Makes me wonder how well it will run a loader or a backhoe. I'll look forward to hearing what you find as a solution.
MarkV
   / haven't a clue need help #9
I have an 841 which is the gas version of you're tractor. Mine is a late model and does not have down pressure. The early models had an "Eagle Hitch" that I am not familiar with. It may have had an external cylinder which could be double acting. My three point cylinder is single acting and is internal. Mine has two sets of rear remotes. My loader is plugged into one set of them. I believe only 6 gpm is available at each remote. That is sufficient for my loader (Koyker) but wouldn't be for a backhoe. The hydraulics are open center and the stated pressure is correct. That's pretty much inline with what was available at the time. Some were better. I think you will need to go with a PTO pump for the backhoe, or it might be possible to run one off the front of the crankshaft. Not sure if there is room there or not. As far as possibly weak hydraulics, you need to confirm this with a pressure gage plugged into a rear remote. Could be a worn pump or the relief valve may need shimmed. Got any pictures of the back end?
Kim
no i don't have any pictures of the tractor yet. I guess my next question is are there any pto extensions available? sounds like a logical step to meif they are available. I do need more flow then that and pressure to run my backhoe and other eguipment but I also need the pto available for all that equipment. How does KWENTLING your loader work on the low flow pressure?? Is it a reasonable option to run the loader off of the tractor's excisting pump and everything else off a auxillary ?
Gravely 160Z Zero Turn Mower (A53117)
Gravely 160Z Zero...
2015 John Deere 410E 40 Ton Articulated Off-Road T/A Dump Truck (A51691)
2015 John Deere...
(4) 250/80-15 Solid Forklift Tires (A52384)
(4) 250/80-15...
2024 78in Screening Bucket Skid Steer Attachment (A51691)
2024 78in...
2024 Deere 317G (A50123)
2024 Deere 317G...
2007 INTERNATIONAL 7400 DT466 SFA 4X4X CHASSIS TRK (A51406)
2007 INTERNATIONAL...
