have to spray it first
   / have to spray it first #1
451johnny
john deere 318
hi everyone I just got this vintage john deere 140-H3 with a 14HP k321 kohler engine that I have to spray it with starter fluid in order to get it started and she'll start as long as its warm but once she cools I have to get the spray again ..I installed a new spark plug air & gas filter and I'm waiting for points and condenser to arrive ..would the points and condenser remedy my starting problem..??? johnny
   / have to spray it first #2
No, that's a fuel problem. Take the carb apart, there is probably a buildup of varnish or crystalline deposit in the main jet or venturi, a common malady on small engines subjected to corn gas or periods of inactivity.
I just had to do this on my lawnmower the other day (Snapper cast aluminum with a Briggs), even with feeding it Seafoam in the fuel, it got where it was hard to start and wouldn't idle. Took it apart, cleaned it out and blew out the passages, starts right up and idles now.
Points and condenser won't hurt, it will make it start easier when it's damp, and just run better with clean electric contacts.
sorry but I forgot to mention that I also took apart the carb and cleaned it even doe it didn't need it.. apparently the guy I got it from must of done it before I did so I'm at a lost right now..?? but I do appreciate your advise johnny
oh thanks just the site I need for my tractor...johnny
wow just the site I need for my tractor....thanks putting it on my fravorites…..johnny
   / have to spray it first #7
maybe the fuel pump isn't working properly. sometimes they are separate, and sometimes they are mounted on the carburetor. you generally need about 1/2 bowl of fuel for it to be picked up properly by the jets.
the fuel is gravity fed..the fuel tank hangs over the carb
I just got the tractor the gas tank hose is going directly into the carb if that isn't gravity fed then I don't know..I read that I could buy one for this engine if I wanted to ..with this engine you could feed the gas with a pump or just gravity.. the engine has the plate cover for where the pump go's but I don't see a need for it ..I disconnected the gas hose from the carb and gas was flowing out very good..thanks I appreciate your advice johnny
Harrell 3605 (A50123)
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
2014 International DuraStar 4300 4x4 Terex BT3063 63FT 15 Ton Crane Truck (A51691)
2014 International...
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
FAKE (A52472)
FAKE (A52472)
2005 INTERNATIONAL 4300 24FT BOX TRUCK WITH TRANSLUCENT ROOF (A54313)
2005 INTERNATIONAL...
