have nose in top
/ have nose in top #1
ashfire18
haleyville,al.
kubota l 2900 gst
hello , i am new at this. have a nose in the top part of motor of a kubota l 2900 gst. does anyone have a ideal what is going on?
/ have nose in top #2
Welcome to the forum!
Are you able to post pictures? It would be helpful to see exactly the area/problem. A lot of members are good at helping with problems encountered
/ have nose in top #3
I think the valves have to be adjusted after a couple hundred hours. Could it be valve train noise that you are hearing? Might need an early adjustment.
/ have nose in top
that was what i thought it might be.will have someone to check that.
2020 FREIGHTLINER M2 4X2 26FT BOX TRUCK (A59911)
2020 FREIGHTLINER...
EZ-GO SHUTTLE 2X2 TXT GAS GOLF CART (A63276)
EZ-GO SHUTTLE 2X2...
2021 CAM P3612TT 6x12 Utility Trailer (A64047)
2021 CAM P3612TT...
2012 FREIGHTLINER 114SD ROLLOFF TRUCK (A59909)
2012 FREIGHTLINER...
2016 UTILITY VS2RA 48FT REEFER TRAILER (A59575)
2016 UTILITY VS2RA...
2016 MACK CXU613 6X4 T/A SLEEPER TRUCK TRACTOR (A59910)
2016 MACK CXU613...
