Have Grapple will play, ah, WORK!!!
   / Have Grapple will play, ah, WORK!!! #1
CampWags
Bronze Member
Alton, New Hampshire
Kubota L3010, Kubota KX 41-3 Excavator Upgraded to Kioti DK65S with cab and Farmi winh
Moving stone!!! /forums/images/graemlins/grin.gif
I wish the loader had more roll-back though. /forums/images/graemlins/mad.gif
   / Have Grapple will play, ah, WORK!!! #2
Nice setup!, Stone? How about boulder.
   / Have Grapple will play, ah, WORK!!! #3
Nice Grapple.
Nice tractor also. I was looking at your FEL design. It looks like to me that the upper bar design (attached to a bell crank on the curl cylinders) would/could keep your bucket level as you raise the bucket. Is this the case?
   / Have Grapple will play, ah, WORK!!! #4
can you guys tell me what brand name tires are on the kioti
   / Have Grapple will play, ah, WORK!!! #5
That's what we like to see, Mud on the tires and doing it's job. Great pic.
Bob /forums/images/graemlins/cool.gif /forums/images/graemlins/smile.gif
   / Have Grapple will play, ah, WORK!!! #6
Look at the front tires in the picture. Thats a heavy stone. I don't think I would try lifting that one with my 3054.
   / Have Grapple will play, ah, WORK!!! #7
That's very impressive. What a nice grapple.
Don't forget to run your front tires at the maximum rated PSI when doing this. Otherwise, you can pop the tire off the rim and also may cause damage to the front end.
John
Once again Kioti John is right! /forums/images/graemlins/blush.gif I started out not knowing how large the rock was. 80% was buried. Once I got it out and saw how large it was I ran in and got the camera. /forums/images/graemlins/grin.gif
I only moved it a very short distance and low to the ground.
The tires are somewhat sunk into mud, up here everything is starting to thaw and turn into mushy mud!!!
My smaller Kubota would always have the front tires come off the rims with any kind of load. so I put in tubes.
Keep the tips coming!!! /forums/images/graemlins/smile.gif /forums/images/graemlins/laugh.gif /forums/images/graemlins/grin.gif
   / Have Grapple will play, ah, WORK!!! #9
It appears you've acquired a pure-bred 'rockhound'. /forums/images/graemlins/cool.gif
Don /forums/images/graemlins/smirk.gif
   / Have Grapple will play, ah, WORK!!! #10
I love to see grapples and tractors working together.
How do you like your self leveling loader? Does the self leveling feature affect your roll-back (curl) on the bucket?
1994 Peterbilt 379 Semi (A50514)
1994 Peterbilt 379...
New Holland TS6.120 4WD 96HP Agricultural Tractor (A50322)
New Holland...
UNUSED AGT XZ20R EXCAVATOR (A51243)
UNUSED AGT XZ20R...
10' Poly Feed Trough (A50515)
10' Poly Feed...
Friesen 110 Seed Tender (A50515)
Friesen 110 Seed...
2007 Kubota M5040D 50HP 4WD Front Loader Utility Tractor (A50322)
2007 Kubota M5040D...
