Hauling RTV
   / Hauling RTV #1
TWO GUNS
Platinum Member
SWAMPS OF LOUISIANA
Fixed up something that made hauling the RTV easier. Installed a 4" cargo strap on the trailer. ( A 3" would do just fine also ) All you have to do in back the unit on the trailer, throw the strap over the back reciever , hook belt on the other side of trailer , and take the pinch-bar (wrecking bar) and tighten down. That darn RTV isn't moving anywhere till you want it to. Made it so much easier, FASTER , safer, than chaining or using rachets, cam-straps to hold it down. Before I rigged this up, I was tired before I ever got a going from putting on four different smaller straps, hooking and couldn't get them near as snug and tight as the cargo strap ~~~~
   / Hauling RTV #2
that rtv sure ain't gonna go anyplace.lol
after going to the clay shoot a few years in a row and watching over 1000 utv'er come in and park i seen one setup that i really like . a guy took and welded some winches the kind that go on the boat trailers . now instead of putting cable on them he put straps . now he welded 6 of them to his trailer one at each corner and one in the middle on each side. and when he achored his utv down it was solid . then the next year a few more people showed up with them hand crank winches welded to their trailers some had cables and some had the straps but it was a nice setup. it pulls from all 4 corners and both sides.
   / Hauling RTV #3
I have one on the front of my trailer that hooks to my FEL. Then I run two chains to the rear with "bear-traps". If I cut (or marked) the rear chains the right length I wouldn't even need the bear-traps but some times I chain to the hoe, others the mower etc..
   / Hauling RTV
I would mark them, don't cut them , that way if you ever wanted to haul something different, you would still have enough chain.
https://www.accessnewswire.com/newsroom/en/healthcare-and-pharmaceutical/slimjaro-vs-burnjaro-reviews-a-comprehensive-analysis-of-benefits-and-1044755
https://www.accessn...
2013 New Holland T4.75 Tractor (A52384)
2013 New Holland...
Pallet of (8) 8 Lug Misc Wheels (A51573)
Pallet of (8) 8...
2013 FREIGHTLINER CORONADO TANDEM AXLE DAY CAB (A52576)
2013 FREIGHTLINER...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A51691)
2025 Kivel 48in...
2017 FREIGHTLINER M2 S/A SWEEPER TRUCK (A51406)
2017 FREIGHTLINER...
