Hatchet or Axe
   / Hatchet or Axe #1
goodoleboy
USA
Still looking since thats half the fun!
I have about 15acres of neglected fence rows with some small growth to big for the trimmer to cut.
I have a brush cutter capable trimmer but no U handle bars for safe operation(purchased used).
Im wanting to use an Axe or hatchet to cut it down.
Whats better for the task a long handled axe or a hatchet.
Im 6ft tall if that helps.
   / Hatchet or Axe #2
How about some long-handled pruners?
Nip the stem off near the ground and drag them out into a pile.
From your description, it's hard for me to tell exactly what type of brush you are looking to remove. Do you have a picture?
   / Hatchet or Axe #3
Trimmer and machete. You can nock out a lot of stuff much quicker with a good machete than either an axe or hatchet. But I guess it depends on how much of it and how little of stuff you are talking about.
   / Hatchet or Axe #5
I would recomend a bow saw. If the growth is to skinny the whole tree will shake and displace the energy of the axe blade. Almost like whacking a rubberband.
If you feed you brush cutter blade into the growth correctly you don't get to much kickback. Plus the blade is at the end of a 5 foot pole. So as long as there is no one standing around a kickbaqck sends the blade head end of the unit out in a wide arc. Unlike a chain saw there is not much chance of the blade coming in contact with your body.
Phil
   / Hatchet or Axe #6
Hatchets are real good for hurting yourself with.
Like others have stated there are many other tools that can be used. Work on your knees and use the axe for big stuff and some of the other tools for the small stuff.
Make sure all the tools are sharp.
Have you considered renting a powered saw made for this type of work. They have long handles and allow you to stand upright. Might be the easiest way to go.
Egon
   / Hatchet or Axe #7
Like Birdhunter1, I'd use a machete, but I can tell you it won't work well unless you know how to use it. Unlike hitting a straight blow as you would with an axe or hatchet, you need to use a slight slicing motion as you strike a blow.
   / Hatchet or Axe #8
A pic and/or diameter range of the stalks would help.
Personally, I do like and prefer what Gatorboy is recommending.
There are 2 types of "loppers". Bypass and Anvil.
Anvil has a blade hitting a stop (like what Gatorboy posted).
The anvil are better if you have a lot of bigger stuff. I've cut through branches on hardwood trees up to almost 2".
The bypass have 2 blades pass each other. Good for smaller or lighter stuff and make a cleaner cut. Good for weeds, grape vines...
If you go with the loppers, it's worth the extra bucks to get a good one.
Brian
   / Hatchet or Axe #9
"Hatchets are real good for hurting yourself with."
When we we're young.. my older brother almost cut his big toe off using a hatchet clearing small saplings.
   / Hatchet or Axe #10
I would offer one caveat about the loppers. People tend to bend over at the waste and cut off the tree or growth. Because of the angle you wind up leaving a perfect little sharp spike in the ground pointing up at you. Do enough small saplings and you leave a field of "pungee sticks".
Phil
Takeuchi Skid Steer (A49461)
Takeuchi Skid...
2025 Kivel Forks and Frame Mini Skid Steer Attachment (A53421)
2025 Kivel Forks...
2000 Safari C-Series 425 40ft Panther Motorhome (A52377)
2000 Safari...
2008 Kenworth (A52377)
2012 DIAMOND CARGO FOOD TRAILER (A53843)
2012 DIAMOND CARGO...
HIGH END MASSAGE CHAIR (A53843)
HIGH END MASSAGE...
