has your PT spilled gas?
   / has your PT spilled gas? #1
miles2go
Bronze Member
So. Oregon
Kubota L3400 HST 4WD
In the arid West fire safety is always a concern.
For that reason my preference is generally for diesel tractors, but the gas-powered PT appear to have an edge in price and ease of maintenance -- especially since there is no dealer available to pick up the PT for service.
Anyone have experience with the gasoline engine PT spilling fuel (or not) during operation or tipping?
   / has your PT spilled gas? #2
I haven't had problems with spilled gas on my older Kohler-powered 425 -- I just fill it to about 4" below the top, so there's no danger of it spilling.
Pictures Engine Compartment -- Mossroad's PT-425
The newer Robin-powered ones are similar.
The large (5 gallon) tank is translucent, so you can see the level of the gas at all times. One morning fill-up will run until lunch-time, then refill it for the afternoon. It consumes between 1 and 1.5 gallons per hour, based on throttle setting and how hard it's being used.
   / has your PT spilled gas? #3
Haven't yet had a problem with spilled gas. I keep the level at least 4" below the gas filler so that if I get on some steep ground, I shouldn't have any worry.
As far as tipping the PT over, I've been on some extremely steep terrain and not yet had the feeling that it was nearing the "tip over" point. The articulation (both ways) keeps the tires on the ground. I've had a little trailer I was pulling roll over but even then the PT stayed stable. Took a little effort to take the twist out of the trailer's pull bar.
I have come to the conclusion that the PT will stand steeper terrain than my nerves. That would be a good thing.
Phil
   / has your PT spilled gas? #4
Miles2go,
As you have a similar fire danger problem, note that the Supertrap muffler I installed on my PT is also an approved spark arrestor. That thread with a photo is here (if the link doesn't work, the thread was "A Quieter PT422" posted 11/17/04): SuperTrap muffler
If it hadn't quieted the machine noticebly, it would have still been worth it to me for the extra spark protection.
Early on I was concerned about the hot exhaust blowing straight down on dry leaves and pine needles. One small glowing piece of carbon and I'd have a real problem during our fire season. Worse would likely be that it'd happen as I was traversing a woodland trail and not notice any fire until it was WAY too late.
The only thing mildly bad about this arrangement is the black exhaust that discolors the tub by the muffler. But since I don't keep mine very clean (and DEFINITELY not as clean as MossRoad's) it hasn't been a real concern.
Phil
   / has your PT spilled gas? #5
I have the 425 that has the gas tank inside the lid. I have never spilled any gas even with some very rough hill side climbing.
The 425 is very low slung, you would have to be on some very steep hillside to even come close to going on its side. Now the "PT PUCKER FACTOR" is one you will watch. That is when you are lifting something very heavy and lift the rear wheels off the ground.. That is a time you could put it on its side. Roll over? going to be really hard to do.
PJ
   / has your PT spilled gas? #6
Yes, it spills regularly BIG TIME.
Pressure builds up in the tank, and I have had what I consider very dangerous 'geysers' of gasoline spewing out of the tank.
PT sent a different cap (vented) which made the problem constant rather than only when opening the cap.
I live at nearly 8,000 feet, and even in the winter, the fuel boils furiously when pressure is released. In the summer, I'm afraid to remove the cap until everything has cooled.
My PT is about 2 yrs. old, and has the steel fuel tank that is built into the cover.
This happens even when the tank is only 1/3 full. /forums/images/graemlins/mad.gif
PT is totally unconcerned.
I believe that the problem is a black metal fuel tank a few inches above a very hot running motor as well as solar gain during intense sun, even in the winter.
I posted a message about this about a year ago.
Mark H.
   / has your PT spilled gas? #7
I was at PT a few weeks ago and they had gone back to the plastic tank. I wonder if you just stated the reason.
Bob Rip
   / has your PT spilled gas? #8
My gas cap seeped out gas as I was running it until about 3 or 4 months ago I got another fuel cap and it seems to have cured the problem. I wish my tank had s screw on type cap instead of the one it has with the two ears.
   / has your PT spilled gas? #9
I had a small "issue" with my gas tank this past Fall. No leaks, but I could smell lots of fumes, especially when backing up and head turned rearward catching the fumes blowing forward into the operator's seat. Turns out that the cork gasket which seals the filler neck to the plastic tank had deteriorated. I replaced it and sealed it with a gasoline resistant gasket sealer, and problem was solved. I think this was more of a wear/tear phenom, not any defect per se.
BTW, there is a decal on the tanks with a max fill line printed on it. That line is ~6+" below filler neck. When working on rough terrain, I usually fill slightly below that, to minimize fuel splashing against the neck.
   / has your PT spilled gas? #10
</font><font color="blue" class="small">( Yes, it spills regularly BIG TIME.
I believe that the problem is a black metal fuel tank a few inches above a very hot running motor as well as solar gain during intense sun, even in the winter.)</font>
<font color="red"> I own the same steel gas tank model PT-425, purchased 2/4. It has the original sealing type cap.
After over 250 hours of operation, I have never experienced any gas problems such as you describe! I refuel to within 1" of the tank top with the engine off, the cover closed, and the filler upward. If the engine is hot, slowly opening the gas cap allows any pressure to harmlessly escape. If I should overfill the tank, the extra gas flows across the tank top, down the sides or back, and quickly and harmlessly evaporates.
One of the first jobs that I did to my new PT was to paint the engine cover and canopy with Satin White. My cooling fan is wired to run constantly.
Even when this photo was taken, gas leakage was not a problem.
</font>
2016 Ford Fusion Sedan (A50324)
2016 Ford Fusion...
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52576)
2019 FREIGHTLINER...
2008 KZ Sportsman Police Bunk 5th Wheel Tri-Axle Travel Trailer (A51694)
2008 KZ Sportsman...
2012 Dodge Grand Caravan Van (A51694)
2012 Dodge Grand...
Takeuchi Skid Steer (A49461)
Takeuchi Skid...
6"x8' Treated Post,  Approx. 28 Piece Bundle  (A52384)
6"x8' Treated...
