Has anyone used a ...
   / Has anyone used a ... #1
daTeacha
Veteran Member
Funk, Ohio
... rear hydraulic doubler? RKO has an item in the flyer for an electrically controlled device that connects to your single remote and has two remotes coming out of it. There is an electric switch that appears to direct the flow to one or the other set of connectors on the doubler, meaning you run one side or the other but not both at once.
At $289 it seems like a relatively cheap way to add another remote without having to plumb in another valve and line set, for example a guy with one rear remote could put this in and have T 'n T capabilities.
Experiences eagerly sought, opinions sought, random comments accepted. :)
   / Has anyone used a ... #2
Man.. for that $$ I think I could plumb in a cheap log splitter valve bank and buy all the hoses and connectors and have more remotes than i needed... cheaper too. Probably plumb it all with QDS.. even the 'feed' side hooke dto the tractors single remote.. that way you could just disconnect it and go..
I know JD sold a dual valve adapter to use on it's batwings that needed 2 valves if used on a tractor with a single valve.. etc.
soundguy
2018 UTILITY VS2RA 53FT REEFER TRAILER (A53426)
2018 UTILITY VS2RA...
2002 JOHN DEERE 450H CRAWLER DOZER (A51406)
2002 JOHN DEERE...
2011 Manac 36245B30 43ft T/A Walking Floor Trailer (A50322)
2011 Manac...
2004 Sterling Acterra Cab and Chassis S/A Truck (A51692)
2004 Sterling...
2014 CATERPILLAR 336EL EXCAVATOR (A52705)
2014 CATERPILLAR...
GALAXY - SET OF 19.5L-24 INDUSTRIAL R4 TIRES (50% TREAD) (A53473)
GALAXY - SET OF...
