Has anyone tried to make an off set mower?
   / Has anyone tried to make an off set mower? #2
LBrown59, I made a ditch mower out of an 18 horse MTD. I removed the 44" deck and fabricated a subframe for the deck and the tractor and mounted the mower deck on the right side of the tractor. I used a belt drive with a couple of extra idlers to maintain belt tension. The deck operated through a 180 degree radius. It worked okay and we used it for several years to mow a steep bank along the driveway and road. The only drawback was that the tractor was not heavy enough and when mowing in the down position it would tend to pull the front of the tractor toward the road ditch. Sorry, no pictures as this was done in my pre-TBN days.
I am currently working on a boom type mower to install on the TPH of my 2210. It is only in the design stage and I am getting the materials together to get started. When I have something in the construction stage I will post pictures. /forums/images/graemlins/smile.gif
   / Has anyone tried to make an off set mower? #4
I've been looking for junked 4' rc to convert to hydraulic drive and mount to my backhoe. I've got steep road banks that can't safely be cut with ridden machinery. Hard to find one with a good deck and bad gearbox.
   / Has anyone tried to make an off set mower? #5
dunno if itll help but heres a thread on making a front mount mower which may give you ideas front mount mower
hope it helps
mith
UNUSED AGT 3 PT 82" ROTARY TILLER (A51248)
UNUSED AGT 3 PT...
INOP/NON-RUNNING 1999 International F-2574 Fuel Lube Truck, VIN # 1HTGGATT4XH682675 (A51572)
INOP/NON-RUNNING...
New/Unused CFG Industrial MX12RX Mini Excavator (A51573)
New/Unused CFG...
2012 CHEVROLET 3500HD SILVERADO LS DUALLY TRUCK (A51247)
2012 CHEVROLET...
UNUSED FUTURE QUICK ATTACH MAST W/ 29" FORKS (A51248)
UNUSED FUTURE...
BW RVB3405 20,000lbs 5th Wheel Hitch Base (A50322)
BW RVB3405...
