Has anyone tried one of these seats?
   / Has anyone tried one of these seats? #1
Sun Treader
Western Virginia
Case IH 495
Amazon.com: Happybuy Universal Pro Seat and Suspension Seat with Adjustable Armrest Industrial Forklift Vinyl Seat with High Shock Absorption for Riding Mowers Tractors Excavator Trenchers Wheel Loader: Automotive
B2601, the tractor is great, the seat is terrible. It leans forward, is absurdly hot, actually leans slightly to the left because of the spring setup. The seat belt is mounted to the frame so every time the suspension goes up and down the belt tightens, and its not really a bad thing but there is no padding at all.
How they get something so basic so wrong is baffling.
So, new seat is in order.
I only put about a hundred hours a year on the machine but also have some lower back problems. Its used for everything from fields to woods to construction. I don't want to spend the $1k plus on the air ride Grammer I know would be great. That's implement money! Anyone found a happy middle ground with a mechanical suspension seat? There are at least three generic vendors on Amazon and more on eBay selling the seat above. Looks decent to me but wanted to know if anyone had laid hands on one.
Thanks,
David
   / Has anyone tried one of these seats? #2
Well seeing how they are advertising a seat, but everything in the description talks about a table think I’d pass. :)
If you want a real comfortable seat go with a grammar air ride. They aren’t cheap but well worth it.
A few companies sell just the air ride base for your current seat for around 400.
   / Has anyone tried one of these seats? #3
Yeah that description is a bit of a red flag.
This unique designed table is an real cross bed table which you can work with your laptop or simply enjoy your breakfast in bed.
Length and Height adjustable for the table laptop cart computer table, length : 55 inches to 83 inches , height (bottom to top): 26 inches to 33.5 inches.
Rolling design of the table laptop cart: With 4 high quality wheels, it's very easy to push away on bed to make comfortable distance if you prefer to watch moves with your laptop on bed, or you could pull it close enough to use it as an workstation.
This Laptop Table is made from sturdy wood surface and steel frame, easy to assemble in 10 minutes with tools attached.
The table laptop cart laptop table Compatible with single, double, queen, king beds.
Besides that it looks like you would need a step ladder to mount the pictured seat.
Well seeing how they are advertising a seat, but everything in the description talks about a table think I壇 pass. :)
If you want a real comfortable seat go with a grammar air ride. They aren稚 cheap but well worth it.
You make a good point there!
Here's the same thing with a more believable description:
Amazon.com: VEVOR Suspension Seat Adjustable Backrest Headrest and Slide Rails Mechanical Suspension Seat Foldable Heavy Duty for Tractor Forklift Excavator: Home Improvement
   / Has anyone tried one of these seats? #7
One idea a while back on here was to remove all springs for the seat and then use a 8in 2 wheel dolly tires tube and is that as an air bag instead of springs.
   / Has anyone tried one of these seats? #8
If I were going to replace a seat with a good suspension seat , I’d definitely go air ride.
Cummins Turbo Diesel Engine with Transmission (A44571)
Cummins Turbo...
Heavy-Duty 4-Wheel Rolling Warehouse Cart  74in x 32in (A44789)
Heavy-Duty 4-Wheel...
2006 PETERBILT 379 (A45333)
2006 PETERBILT 379...
Case IH 455 Round Baler (A44789)
Case IH 455 Round...
AGT QA Pallet Forks (A44502)
AGT QA Pallet...
2023 ATLAS COPCO XAS 110 AIR COMPRESSOR (A45333)
2023 ATLAS COPCO...
