Mowing Has anyone run a 90" mower with a JD 3520
   / Has anyone run a 90" mower with a JD 3520 #1
DHAUG
I have a 3520 cab tractor that puts 30hp (I think) to the pto shaft. My dealer says it will turn a 7 foot 3pt finish mower or a 15 foot batwing finish mower. The batwing is out of my price range, but I would like to get rid of my MMM in favor of a 3pt mower, and I can not decide between a Landpride 6 foot, or a Landpride 90" mower. If my tractor will have enough power, I would like to get the 90" mower. Has anyone run one of these, or something like it behind a 3520?
I like these two mowers better than the 84" that landpride offers because of blade tip speed, but I am open to suggestions.
Thanks in advance for your help on this.
Dan
   / Has anyone run a 90" mower with a JD 3520 #2
I just bought a 84 in landpride mower for my 4310 which has 27 pto hp. I can bog it down in some very heavy grass but no more than my 5 ft brush cutter on the same grass going about 7.5 mph travel speed. About a foot high heavy grass going up a hill.
I think a 90 in mower would be no problem.
How is your cut quality mowing that fast? With John Deere's 72MMM I can only go about 3.5mph if I want a good cut quality. I rarely cut grass more than 7" tall. That is why I am interested in the 90" mower over the 84" mower (it has a higher blade tip speed).
   / Has anyone run a 90" mower with a JD 3520 #4
Dan
I think you would be pushing it with a 15 foot batwing. You would slow down to a crawl.
But I think the 90" finish mower would be fine.
   / Has anyone run a 90" mower with a JD 3520 #5
Johnagain said:
I can bog it down in some very heavy grass but no more than my 5 ft brush cutter on the same grass going about 7.5 mph travel speed. .
7.5 MPH? Holy cow that's flying. Does it actualy give a satisfactory cut?
   / Has anyone run a 90" mower with a JD 3520 #6
Hi:
I ran a 15' wing mower with my 3720 cab (There is a thread with pictures... ).
I mowed at up to 6mph, had to slow down to 4mph a couple of times.
You'd have absolutely no problem running a 90" with a 3520. I've actually have an 84" RFM ordered. Anything larger than 84" (The JD 90 or 110) I looked at had a much lower blades speed and most had swinging (rotary cutter type) blades that wouldn't give as good a cut quality?
Does the 90" landpride your getting have fixed or swinging blades? What's the blade speed? (Most I looked at were below 15,000 for that size.
orlo said:
Hi:
The blade tip speed is shown at 18,500. I beleive these are regular non-swinging blades. Here is the website that I am getting the information from.
http://www.landpride.com/ari/attach/lp/public/specs/310-229s.pdf
thanks for the advice, and I would love to hear opinions on this particular mower.
Dan
   / Has anyone run a 90" mower with a JD 3520 #8
That looks sweet. 3/4" to over 5 is a great range. I wish I looked at those before I ordered my 84" Frontier (Made by Woods). I just looked at Frontier and Woods. Woods makes a 90 but it's swinging blades, etc.
18,500 is faster than my 7 iron MMM (is around 18000). You'll get a great cut with that. Tip speed also helps when you are cutting high stuff as it mulches it up better.
Do you think I will get a better cut than the 72MMM I am using now? I have the large R-4 tires and wonder if the extra tires (the rear's) running over the grass before the mower gets to it will affect the cut drastically.
   / Has anyone run a 90" mower with a JD 3520 #10
I don't think that that is going that fast for a rough cutter.... I go along in 2nd in our MF135 with Multi Power and I think that is about 10MPH. (But that is with a 6 foot cutter which is pretty small for the tractor)
1998 C6500 Chevy, 3126 Cat Engine (A52384)
1998 C6500 Chevy...
2014 Jacobsen AR3 Commercial Mower (A50322)
2014 Jacobsen AR3...
2017 NISSAN NV200 VAN (A51406)
2017 NISSAN NV200...
2000 International 4700 (A50120)
2000 International...
2025 Icon Electric Bike (A50324)
2025 Icon Electric...
