Has anyone put a hydraulic cooler on a T5C or T5D?
   / Has anyone put a hydraulic cooler on a T5C or T5D? #1
Terre Haute
T5D
After about 200 hours my 10w40 hydraulic oil smells burnt. Has anyone put a hydraulic cooler on a T5C or T5D, I have one of each? If so, please post pics and tell me where you got.
Or has anyone used full synthetic oil in hydraulics? I've been told synthetic oil stands up to higher temps.
Thanks, Geo
   / Has anyone put a hydraulic cooler on a T5C or T5D? #2
Is there an issue that is causing oil heating?? (worn pump,,, etc)
Using loader or backhoe cylinders a LOT should not cause heating ,,,
but a worn pump, or hydraulic motor can wreak havoc on oil.
Major use at high ambient temps can sometimes cause a need for a cooler,,, otherwise,, I would be looking for a cause.
My T5D has a new torque motor. I do use them when it's hot.
How would you tell if pump is bad? I do have an IR thermometer. What is the normal operating temperature for a pump? Can pumps be rebuilt or do I buy a new one?
   / Has anyone put a hydraulic cooler on a T5C or T5D? #4
I can not give you a "cook-book" for diagnosing a bad pump/motor,,, that is not in my knowledge base.
Another thought,, do you have a power beyond circuit on this machine?
improper connection of the power beyond will heat the oil,,, RIGHT now!!
I put a temp probe in hyd sump and noticed my overheating issue is really caused by going up hills. Temp is fine while working on level ground, loading or digging. I've concluded the terramite is not a hill climber nor is it a transporter of materials. So I use a dump trailer to move dirt and mulch, not the terramite. Terramite is a loader not a mover.
Plan to use my terramite on level ground and see if my hyd oil smells burnt.
goe
2012 PETERBILT 367 (A50854)
2012 PETERBILT 367...
2007 JOHN DEERE 624J WHEEL LOADER (A51406)
2007 JOHN DEERE...
HONDA EU2200 INVERTER (A50854)
HONDA EU2200...
2020 Peterbilt 389 Tri-Axle Sleeper Cab Truck Tractor (A49461)
2020 Peterbilt 389...
VERMEER VACTRON LP555 DT HYDROVAC TRAILER (A50854)
VERMEER VACTRON...
2020 KUBOTA RTV...
